Get This stuff out of my Garage
Wheels up Director
Everything must go, Most items are brand new except as noted. Prices do not include shipping. Will accept cash, check(must clear first), MO or paypal(SORRY NO CREDIT CARDS).
Aeromotive A1000 Fuel Pump- $200 SOLD
Aeromotive p/n 13109 Fuel regulator- $90 SOLD
Aeromotive 12304 Fuel Filter- $50 SOLD
SVO 30lb Injectors- $150 (used less than 2000 miles) SOLD
Weld Magnum 15x3.5 Front wheel- $475
LS1 Edit Model Year 2000- $275
Performaire o2 Weather Station- $475
Hooker LT Coated headers- $425
Schubeck Lifters- $175
JPR Stage 2 HVLD heads( valves are new,Ferrea's. springs are new but have surface rust, I think the Ti retainers are new as well. Don't have a clue as to want they flow but I'd imagine they're one of Joe's good pairs) $500
SLP Double Roller Timing set- $100
ASP UD Pulley non-sfi- $80 (used less than 2500 miles) SOLD
Comp Cams Hardened pushrods 7.35"- $60
JPR Electric water pump- as far as I know this may be the only one in this version. Its the tubular version, CSI remote water pump. You will need to get some braided line and fittings to be able to install this- $350
Stock water pump - $50 SOLD
4L60e- Stock with deep truck pan, 4500 miles need to replace drain plug- Will NOT Ship this, Will meet you- $350
Oil Pan Y-Body- $100
LS1 2000 Block- $250
Weld Drag Lites 15x3.5- $180 15x8- $230 SOLD
M/T ET Drags 26x8-15 $175
M/T Sportsman front 8-ply- $130 SOLD
Stock front hubs w/ Longer stock studs- $85
ARP Main Stud Kit- $125 SOLD
ARP Rod Bolts- $65 SOLD
Stock Crank- $90
ABS Module- $200
Stock Front engine cover - $30
LS1 Stock Valley cover - $30
MSD plug wires- $50
Stock Aluminum Driveshaft with Auto Yoke- $110
Coil Packs- $110
Poly Torque Arm Bushing- $12
Poly Trans Mount- $35
Power Steering Pump w/ Pulley- $70 SOLD
Yank Thruster Pro 4500 Converter- $575
Stock Starter- $50 SOLD
Engine Pedestals- $40
Stock Fuel Rail- $30 SOLD
Alternator- $50 SOLD
Hood Shocks- $20 SOLD
I think this is it. Also once the items are paid for it won't be until the weekend before I'll be able to ship the items out.
Stock Crank- $90
ABS Module- $200
MSD plug wires- $50
Coil Packs- $110
send pics of the headers to chuckbrigham@hotmail.com I dont get on here much but i'm looking for some headers pretty quick.
