MSD BAP install question.
I did a search with no luck. I need to know if any of you have pics of your setups. I would really like to have the BAP in the rear wheel well where the disc changer goes but Im not sure about the vaccume/boost line, I dont think it would be a good idea to run the line all the way to the back.
does anyone have installation instructions?
Is it safe to run it on at all times?
The BAP has a very long electric line that goes to the boost activation switch. Plumb the switch into a port that has boost then run the wires to that, no need to run a vacuum line to BAP.
Ok so let me see if Im understanding this right. To keep the BAP mounted in the rear so it wiil not be seen, I wiil have to run a boost activation switch up front then run the two wires that are approx 10-17 feet long (red and black wire) to that?
Will this work the same as running a boost line directly to the BAP?
Is there an instuction manual online for these things? I looked on msd website and they dont have it.
I can take a picture of mine, it's a KB though. I personally would not run a vac/boost hose all the way to the back, just use the electric line.
