106MM 347 in a GN build thread
Old Apr 8, 2007 | 11:05 AM
Whistler's Avatar
Sawzall and Welder Mod
Default 106MM 347 in a GN build thread
Here's a few quick shots... I'll post more when the headers come back from the polisher.
Stock LS1 block and crank with a cleanup hone and Eagle/Mahle combo
Ported 317s with GM MLS gaskets, stock diam. studs main/head
400 with a brake and NC converter
Turbo system- 321 double slip merged headers, 3" crossover and 5" DP
This is just a "get it running" engine to be replaced with a Warhawk later on.
Old Apr 8, 2007 | 11:07 AM
ls1-ss's Avatar
MY God, the damn turbo looks bigger than the engine
Old Apr 8, 2007 | 11:08 AM
HUNTER02SS's Avatar
Where is the engine,I just saw one big azz turbo in there!!JK. That look's great.That poor 347!!Ha Ha
Old Apr 8, 2007 | 11:10 AM
SLPSS99's Avatar
That is amazing!!
Old Apr 8, 2007 | 11:13 AM
rking's Avatar
Did you custom make your mounts and crossmember? I am gathering parts for my TT 402 L92 GN build and just trying to find those parts before I have to start fabbing them myself .
89ws6formula50's Avatar
Oh man, Im gonna have to keep an eye on this thread. Im looking at parts now to do a 370 single turbo in my GN. I was just looking at the OFI 98-02 kit. The headers and x-over look like they may fit the G Body chasis. What are you using for headers??
Old Apr 8, 2007 | 11:14 AM
Josh@KY-Turbo's Avatar
That is gonna be wild.
Old Apr 8, 2007 | 11:19 AM
I just noticed, you have a rack n pinion steering conversion on there too
Old Apr 8, 2007 | 11:28 AM
rking's Avatar
89WS6, I have heard that the Fbody headers will fit into the Gbody without any mods. I havent tried it myself, but just what I have been told. On my TT, I want to retain the AC and I want it to fit to my specs, so I am custom making mine. Have you looked into motor mounts and a crossmember. Just wondering if anyone is making one, or am I also going to have to fab that up?
Old Apr 8, 2007 | 11:53 AM
Whistler's Avatar
It's got custom solid mounts with custom merged 321 headers. They're being polished right now.
Old Apr 8, 2007 | 11:57 AM
rking's Avatar
Did you have to modify the frame crossmember any and what oil pan did you use?
Old Apr 8, 2007 | 12:02 PM
Whistler's Avatar
No modifications to the frame, LS1 f body pan
Old Apr 8, 2007 | 12:07 PM
There are mounts and a x-member available. Im at my sisters but as soon as I get back to my place I will post the link. Im also thinking of using a 4L80E which I already have. I have a TCI TH400 with a JW Ultrabbell also but Id like to have OD back. I also have a FAST on the car now but thinking of selling it and running stock PCM with LS1edit or similair. I would like to make 700-750rwhp, using a single PT88, right now Im at 554rwhp on my v6 @ 22 psi on 93 and alky. For now, I maky get a 4 bolt housing for the T70 I have until I can upgrade to the 88 since I have the 70mm already.
Old Apr 8, 2007 | 01:09 PM
SSilverSSurfer's Avatar
my lord thats a big f'n turbo, good luck
Old Apr 8, 2007 | 02:05 PM
John Wilde's Avatar
I can't wait to see this thing run at the WSN.
I hope he has time to drive with all the customers around.
Looks like Chow's Car won't be the only stock suspension Turbo Buick
in the 7s for long!!!!
Old Apr 8, 2007 | 02:17 PM
Whistler's Avatar
Old Apr 8, 2007 | 02:31 PM
THE_SUPRA's Avatar
giggity giggity!
Old Apr 8, 2007 | 03:00 PM
http://www.hotrodlane.cc/
these guya have a bunch of stuff for the swap
Old Apr 8, 2007 | 03:09 PM
Whistler's Avatar
If you want to go really fast, they don't have a damn thing
Old Apr 8, 2007 | 03:16 PM
rking's Avatar
Where are your coils mounted?
