Ls1 coil packs and brackets +parts
Old Oct 10, 2007 | 08:06 PM
JJz28's Avatar
Default Ls1 coil packs and brackets +parts
F/S
Set of low mile coil packs and brackets $100
7. 5.3 6.0 fuel injectors $70
timing cover with bolts and gasket $25
valley cover with bolts and gasket $25
rear cover with bolts and gasket $25
water temp sensor $5
oil pressure sending unit $5
low mile set of rocker arms $50
low mile set of lifters with bolts and trays $50
1 set of low mile #706 5.3 heads $125
truck intake manifold with fuel rails $100
truck brackets- power steering bracket with low mile power steering pump,alt
bracket,air compressor bracket $100
truck oil pan, windage tray, pick up tube $75
low mile truck water pump with thermostat $40
Old Oct 10, 2007 | 09:15 PM
scottie dont's Avatar
ill take the water temp and the oil pressure sending unit. sending pm
- Scottie
Old Oct 10, 2007 | 10:01 PM
1BadDime's Avatar
PM sent...
Old Oct 16, 2007 | 09:44 PM
LT12LS1's Avatar
hey i need those coil packs a.s.a.p. please please please tell me there still avail...???
Old Oct 16, 2007 | 10:17 PM
vaticano's Avatar
do the rockers come with mounting brackets and bolts, i would also like the lifter trays and bolts if you will separtate
Old Oct 17, 2007 | 06:24 PM
vaticano's Avatar
money sent
Old Oct 17, 2007 | 06:34 PM
1badA3Z's Avatar
pm sent,thanks
Old Oct 18, 2007 | 10:35 AM
mbeidel's Avatar
I would like to have the following if you still have them?
Front Engine Cover
Rear Engine Cover
Intake Valley Cover
Thank you
Old Oct 22, 2007 | 05:26 PM
vaticano's Avatar
i got the parts thanx
Old Oct 22, 2007 | 09:20 PM
rx_treme's Avatar
Got the coils thanks!
