Major demodding sale, eagle 383,fast90,moser 9",QA1's,236 cam, more.
Guys I am demodding my SS and putting back to a cam only set up for the street. I bought a 93 mustang coupe with a LS1/th400 setup in it and this will be my drag car. So to help pay for the mustang, I am selling all my go fast parts and suspension.
I already sold some of it local and here is the rest of it.
Most parts have 9,000 miles or less on them and in perfect condition.
Prices will be with out shipping included and add 4% for you paypal users.
I am needing some stock parts, listed at the bottom! Thanks guys!
I will post pics in a few.
Flow master catback $150 + shipping.
Pro-M mass air sensor, very low miles, paid $300 will take $150 shipped.
TNT F1 90mm ring,with pro-flow purge and ash tray switch panel, NX bottle heater, MSD window switch with 3K and 6K pill sets, jets for 75/100/150hp shots. $600.00
SVO green tops, 42lbs injectors, 2K miles $275.00 Shipped!
Racetronics/Delphi 32lbs injectors 4K miles $250.00 shipped!
RPM built T-56 2000 miles level 4, with exchange of a perfectly good working T-56 must be verified by RPM or me. $850.00
Racetronics 255 intake pump with hot wire kit.7000 miles. $150.00
QA1 coil over rear shocks 275# springs, they need to be sent in, I turned the **** to far and the fluid leaked out of one of them, it only cost 35 bucks each to re build. $275.00
Brand new never built 383 short block, eagle 4340 4" crank, eagle 4340 6.125 rods, diamond -2cc pistons, moly rings, clevite H series bearings rods and crank, durabond cam bearings already installed in block, block is already machined for the assembly, and rotating assembly is already balanced. $2800.00
The parts I need are 224 or TR230 cam or something in that range, mack mid length headers or pace setters.
I may be adding more things soon, so check back from time to time.
i have ls6 intake mac mids, wit the y pipe, and an 80 mm bbk throttle body, and a 10 bolt. and i'm in ohio, pm me , let work out a deal. interested in the rear end, throttle and fast intake. let me know.
Interested in the spohn solid motor mounts. From the pics, I see you had them on a stock k-member. Will these work with any K-member?
Was there an issue with these mounts cracking blocks?
Thanks in advance
Thanks in advance
The mounts work great. I love them. I'm not sure if they fit with other K members or not. I don't see why not as long as the bolt holes line up. They will not crack the block. My motor sat on them with no tranny in it. And it supported it fine.
Will you go $90.00 shipped to 14305?
