Unemployed Moderator Garage Sale
From: Central Indiana Honors: 4th grade spelling bee contestant
Ok, I recently lost my job, so I'm in need of some cash. I had a big sale on ebay, and this is what is left.
I need to move this stuff so that I can keep the lights on! PayPal payments only please...carart1@yahoo.com
Firebird Camaro AC Condensor Tube LT1 V8 L32 V6
Description of item(s): AC Condensor tube that should work on the 1993-1997 Pontiac Firebird, 1993-1997
Pontiac Formula, 1993-1997 Pontiac Trans Am, 1993-1997 Pontiac Firehawk, 1993-1997 Camaro, 1993-1997
Camaro Z28 & 1996-1997 Camaro SS. The part is in excellent condition. This part attaches directly to the
ac condensor. This part was removed from a 1995 Pontiac Firebird.
$7.00 Shipped
Supplemental restraint sensor Firebird Camaro 93-97
GM part #16154671
Description of item(s): I'm not 100% sure what this item is...I know that it's tied into the supplementa restraint
system because of the yellow electrical connector plug. It was mounted in the very front of the car. I've provided
photos of the items original location on the car (mounted in the location of the two bolt holes). I tried to do a part
number search, but my source says that the part number either has been changed or the part is no longer available.
This item was removed from a 1995 Pontiac Firebird.
$7.00 Shipped
Pontiac Firebird Chevrolet Camaro 3.4L L32 V6 Air Intake
GM part #25162700, 25098350, 25099074, 25099578
SOLD TO badinfluenceRS
GM Firebird Camaro 3.4L SFI V6 L32 Alternator & pulley
GM part #03022384
Description of item(s): Delco Remy Alternator found on 1993-1995 Pontiac Firebirds and Chevrolet Camaros
equipped with the 3.4L SFI V6 (engine RPO L32). Item is in good shape. Includes alternator belt pulley &
necessary hardware. Item was removed from a 1995 Pontiac Firebird.
$35.00 Shipped
Firebird Trans Am Camaro Belt Tensioner 3.4L L32 V6
GM part #4696663, 4750851, (10238703 pulley)
Description of item(s): Belt tensioner found on 1993-1995 Pontiac Firebirds and Chevrolet Camaros
equipped with the 3.4L SFI V6 (engine RPO L32). It may not look like much, but it still gets the job
done! The tensioner also comes with the tensioner pulley (part #10238703) and mounting hardware.
$10.00 Shipped
$7.00 Shipped
GM part #16154671
$7.00 Shipped
GM part #03022384
$35.00 Shipped
$10.00 Shipped
3.4L SFI V6 L32 Ignition Coils 93-95 Firebird Camaro
GM part #1103963
Description of item(s): Ignition coils found on 1993-1995 Pontiac Firebirds and Chevrolet Camaros
equipped with the 3.4L SFI V6 (engine RPO L32). Item is in good condition and worked just fine at the
time it was removed from the car. Included with this item is the necessary mounting hardware. Item
$15.00 Shipped
Driver's side underdash panels 93-02 Firebird Camaro LS1 LT1 L32
SOLD TO DAVE00
Firebird Camaro V6 Guage Cluster Speedometer 93-97 LT1 L32
GM part #16136034
Description of item(s): Factory Pontiac Firebird V6 Guage Cluster found in 1993-1997 Pontiac Firebirds
equipped with the 3.4L SFI V6 (engine RPO L32). I assume that this guage cluster can also be used in
the Chevrolet Camaro that is also equipped with the 3.4L SFI V6. Can also be used in LT1-equipped Pontiac
Firebirds and Chevrolet Camaros (though the speedometer only reads to 110). Item is in good shape, and
all guages worked at the time of removal. There are a few light scratches in the clear lense around where the
steering column would be when installed in the car. The odometer currently reads 157,898 miles.
$25.00 Shipped
3.4L SFI V6 L32 PCV Valve Tubing 93-95 Firebird Camaro
Description of item(s): PCV Valve tubing found on 1993-1997 Pontiac Firebird and Chevrolet Camaro
models equipped with the 3.4L SFI V6 (engine RPO L32). Item is in great condition. Includes mounting
bracket. Parts were removed from a 1995 Pontiac Firebird.
$10.00 Shipped
3.4L V6 Power Steering Pump Mount & Pulley Firebird Camaro LT1
GM part # unknown
Description of item(s): Power steering reservoir pump, the reservoir engine mount & the belt pulley for
a 3.4L SFI V6 (engine RPO L32) found on the 1993-1995 Pontiac Firebird & 1993-1995 Chevrolet
Camaro equipped with the 3.4L SFI V6. Items are used but in great condition. Items were removed
$40.00 Shipped
Radiator 3.4L V6 LT1 LS1 V8 Firebird Camaro
GM part # unknown
Description of item(s): Radiator pulled from a 3.4L SFI V6-equipped 1995 Pontiac Firebird. This item could be used
in the 1993-2002 Pontiac Firebird, 1993-2000 Pontiac Formula, 1993-2002 Pontiac Firehawk, 1993-2002 Pontiac
Trans Am, 1993-2002 Chevrolet Camaro, 1993-2002 Chevrolet Camaro Z28 & 1996-2002 Chevrolet Camaro SS models.
Some modification may be required on some models. Item is in good condition. When looking at it head on, there
is a slight curve to the radiator. However, it lays flat and has no leaks. As mentioned before, this item was removed
$40.00 Shipped
3.4L V6 L32 Rocker Arms & Parts Firebird Camaro 93-95
GM part # unknown (not stamped on part)
Description of item(s): Rocker arms, pushrods, rocker studs, and guide plates for the 1993-1995 Pontiac
Firebird and Chevrolet Camaro equipped with the 3.4L SFI V6 (engine RPO L32). Parts are used, but
appear to be in great shape. Before being removed, they worked flawlessly in the car. All the parts
3.4L SFI V6 L32 Throttle Body Firebird Camaro 93-95
Description of item(s): Throttle body found on 1993-1995 Pontiac Firebird and Chevrolet Camaro
equipped with the 3.4L SFI V6 (engine RPO L32). Installation hardware is included. Part was removed
$15.00 Shipped
3.4L SFI V6 L32 Firebird Camaro Throttle Cable Cover 93-95
GM part #10174474
Description of item(s): Throttle cable cover found on 1993-1995 Pontiac Firebirds and Chevrolet Camaros
equipped with the 3.4L SFI V6 (engine RPO L32). Installation hardware is also included with this item.
Item is in good shape. Removed from a 1995 Pontiac Firebird.
3.4L V6 L32 Thermostat Housing Firebird Camaro 93-97
GM part #10151656
Description of item(s): 3.4L SFI V6 (engine RPO L32) thermostat housing found on the 1993-1995
Pontiac Firebird and Chevrolet Camaro equipped with the 3.4L SFI V6 (engine RPO L32). Item is
used, but in great condition. Included is the necessary mounting hardware. Part was removed
$10.00 Shipped
Pontiac Firebird Formula Trans Am Upper Radiator Support 93-97 LT1
GM part #10248562
Description of item(s): Upper radiator support for 1993-1997 Pontiac Firebird, 1993-1997 Pontiac Formula,
1993-1997 Pontiac Trans Am, 1993-1997 Pontiac Firehawk, 1993-1997 Chevrolet Camaro, 1993-1997 Chevrolet
Camaro Z28 & 1996-1997 Chevrolet Camaro SS. Item is in excellent condition. Included is all the hardware and
the rear rubber gasket. All three V6 Firebird factory decals are included (part #10260657, #10115873 & #24504073).
The Accessory drive belt routing decal and the emmission controls information decal are both peeled up slightly on
one corner. This part was removed from a 1995 Pontiac Firebird.
3.4L SFI V6 L32 Valve Covers Firebird Camaro 93-95
GM part #10191717 (driver's-side valve cover), #10191710 (passenger-side valve cover)</b>, part numbers for oil
cap/shaft & metal tube are unknown
Description of item(s): 3.4L SFI V6 (engine RPO L32) valve covers, oil cap/shaft & metal emissions
tube (that connects to the passenger-side valve cover) found on the 1993-1995 Pontiac Firebird and
Chevrolet Camaro equipped with the 3.4L SFI V6 (engine RPO L32). Items are in used, but in great
shape. Mounting hardware is also included with this auction. Items were removed from a 1995
Pontiac Firebird.
$20.00 Shipped
3.4L SFI V6 L32 Water Pump Bolts Firebird Camaro
Description of item(s): 3.4L SFI V6 (engine RPO L32) water pump bolts found on the 1993-1995 Pontiac
Firebird and Chevrolet Camaro equipped with the 3.4L SFI V6 (engine RPO L32). Bolts are used but in
good condition. Missing a bolt or two or replacing with a new/rebuilt pump and don't have the bolts? Here's
your chance to correct that situation. Bolts were removed from a 1995 Pontiac Firebird.
$7.00 Shipped
GM part #1103963
$15.00 Shipped
SOLD TO DAVE00
GM part #16136034
$25.00 Shipped
$10.00 Shipped
GM part # unknown
$40.00 Shipped
GM part # unknown
$40.00 Shipped
$15.00 Shipped
GM part #10174474
GM part #10151656
$10.00 Shipped
GM part #10248562
Pontiac Firebird.
$20.00 Shipped
$7.00 Shipped
3.4L SFI V6 L32 Water Pump Pulley Firebird Camaro 93-95
GM part #10166377
Description of item(s): Water pump pulley found on the 1993-1995 Pontiac Firebird and Chevrolet Camaro
equipped with the 3.4L SFI V6 (engine RPO L32). Pulley is in good shape, and includes the mounting
hardware. Part was removed from a 1995 Pontiac Firebird.
$7.00 Shipped
Firebird Camaro Satisfied Rear Disc Brake Pads 93-97 LT1
Satisfied Part #PR413-C
SOLD TO Malicious
Auto Meter Tachometer Bracket Extended Base #5265
SOLD TO 55chevy
Help me keep the bills paid!
Non-Automotive Stuff: https://ls1tech.com/forums/non-automotive-classifieds/822296-unemployed-moderator-garage-sale-miscellaneous-stuff.html
LS1 Stuff: https://ls1tech.com/forums/showthrea...=1#post8209063
First come first serve! PayPal is: carart1@yahoo.com
GM part #10166377
$7.00 Shipped
SOLD TO Malicious
SOLD TO 55chevy
Sorry bout the job Scott I wish the best for you especially with the holidays upon us. I am interested in the T/A lower dash covers, can you send me a pic of the back of the lower dash (the part with the hatch button), and these are $15 with shipping?
Email to wdaveweaver@hotmail.com
