converting from 98 to 99-02 system
Old Apr 20, 2008 | 06:53 PM
ApacheDrill's Avatar
Default converting from 98 to 99-02 system
I have a 98 and currently have the tank out to upgrade the fuel pump. My questiion is, if i swap to a plastic cell and the 99-02 pump, will it all hook up the way the 98 system did? or is there more to it? Would it be worth the hassle to save a few pounds? Any help on this would be appreciated.. Thanks
Old Apr 20, 2008 | 07:19 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The connections are different, so you will have to fabricate a harness.
You basically gain nothing except for a small amount of weight.
For drag racing, the '98 pump is in a superior location & has less chance of losing pressure under acceleration. Personally I would stick with the '98 setup unless the tank is rusted internally.
Old Apr 21, 2008 | 05:13 AM
Thanks Lonnie i am sending you a PM
Old Apr 21, 2008 | 08:31 PM
thanks Lonnie for setting me up and pointing me in the right direction..
Old Apr 22, 2008 | 08:08 PM
LS1TECH Sponsor
Glad I could help.
