Huge Garage Sale !!! Brake, Engine and Suspension parts with Pics !!!
Everything is "OBO" so if it sounds like a lot of $$$ make me an Offer, I'll not be offended
+ Plus Shipping and 3% paypal--------------------------------------------------------------------------
LS1 Rollermaster Double Timing Chain used 5K miles $80 SOLD !!!
Perimeter Valve Covers $60
Used Center Valve Cover Gaskets Low Miles $10
Set of Front/Rear Stock Shocks/Springs from a '00 SS with only 30K miles $150
Rear Springs Rubbers $30
3 Channel 3.23 Rear End with 50K miles in perfect Shape $295
Rear End Housing with Relocation Brackets Welded $85 (No Posi or Axels included but Available)
Axels No Traction Control $35 Each
Auburn Posi Low Miles $195 (over $400 new)
LS1 Crank (needs to be cut) $65
Rusty LS1 Crank but working when removed $ make an offer
LS1 Rotors in Nice Shape $65 Pair
Stock Air Box, Rad Support, Filter and Filter Base from a '00 SS $85 Add $20 for a K&N filter !!!
This is over $500 from the Dealer (and that is an Special Order)
LS1 Pass Side Spindle/hub $80
LT1 Spindle/hubs $60 each
LT1 Front Performace Brake Pads Pads $60
LT1 Performance Front Drilled Rotors $80
Stock Upper and Panhard Bar from '00 SS 30K miles $30 each
LS1 Belts with Low Miles $35 Pair
LS1 Front Calipers, Brackets and Lines 30K miles - Front $125 - Rears $100
Hawk Performance Brake Pads used 3K miles $65 (almost a $100 new)
Front Bosch O2 Sensors with low miles $75
Set of 2 O2 Sensors with low miles $65 (Only 2 Left)
Stock Y-Pipe from a '00 SS low miles $40
Flowmaster Catback with 3" pipes and Stainless Tips $230 (over $450 new)
Brake Booster $45
Brake Master Cylinder $60
Trottle Position Controller from a '00 SS $120
LS1 Heatter Hoses $45
LS1 Oil Pan Tray $30
LS1 Fans in Perfect Shape $125
I'll add more stuff later so keep coming !!!
