454 BBC...with electronic fuel injection
454ci BBC.
What kind of RWHP could be expected with the best flowing heads available and a carb style type intake? Pretty big cam, but nothing stupid. 11.5:1 cr. M6 tranny.
Is 750 RWHP possible N/A.
that would be mght be a tad to high.. but if u have all the money to do t.. it could be aceaivable,, but not on pump gas, way above 7,000 rpm. money money, build a 496 about the same cost of 454, stoke it, best heads are the aftermarket 4 valve heads, cost 15,000 plus!. more like 20,000... but i belieave 700 + rwhp is not likey with a n/a pump gas 454, would have to be blown, fi,
Yes its possible, and you don't need to get crazy with 4 valve heads. Hot Rod built a 540BBC that made 793hp on pump gas, while not your 750 RWHP goal its going to be damn close and I am sure you could do something a little extra to get a little more horse power out of it and still keep it N/A.
Article-
http://www.hotrod.com/techarticles/e...est/index.html
Article-
I always wondered something.
What would happen if two people built two different 454ci engines.
One was a BBC 454ci and the other was a LSx 454ci.
On 93 octane pump gas, thats the only rule for both builds, which could be built to make more HP for a street car. Normally aspirated. Buy any parts that are available.
My guess:
I would have to guess that the BBC 454ci would whip the LSx (small block) simply because the head choices for the BBC will allow much more flow.
My guess:
If all it had to do was run on 93 and be N/A it would be pretty close IMO. I think the BBC would win just because of the massive bore and would definitely be more reliable. With the high dollar components and a nice set of heads I think a LSx would be comparable, but definitely easier/cheaper with the BBC.
So if two people had $14,000 to spend, one builds a BBC 454 and the other a LSx 454......whatever parts they want.......93 pump gas...11.3:1 compression each.
Who wins the power/torque contest?
We already know the BBC will kill the LSx in reliability.
What kind of power could the 454 BBC make? RWHP?
