Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Rocker arms backing off
Old 10-11-2009, 12:14 AM
jh_shady01's Avatar
Default Rocker arms backing off
355, world sportsman heads, manley studs. My rocker arm nuts keep backing off, the studs arent stripped, the nuts are fine, what is the deal?? Push rods too short, maybe? They are stock length.
Old 10-11-2009, 01:19 AM
In-Zane Moderator
ZONES89RS's Avatar
Poly locks were made for a reason.
Old 10-11-2009, 09:20 AM
Badass355ciz28's Avatar
i agree
Old 10-11-2009, 12:51 PM
jh_shady01's Avatar
Looks like I'll be investing in a set, Thanks.
Old 10-12-2009, 09:28 PM
k5383's Avatar
I was having a problem like this too, if you can't afford the poly's yet.
Try adding a second nut ontop of the first one.
Old 10-12-2009, 10:36 PM
jh_shady01's Avatar
I tried that but its not working either. I went ahead and ordered the poly locks along with 1.6 roller rockers, should be here wednesday. Should make for something fun at the track friday night.
Old 10-13-2009, 02:08 PM
cambirdracing's Avatar
When you put the poly's on there, tighten the set screw and then tighten the nut about another 1/8 turn with the set screw. Don't over do it, you can break the nut. They won't back off this way. I can run my solid roller cam all year and adjust maybe 1 or 2 at the end of the seson.
Quick Reply: Rocker arms backing off
