Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
crankcase venting
Old 10-18-2009, 11:22 AM
tunedports10's Avatar
Default crankcase venting
Currently have a lot of crankcase pressure pushing oil out seals and what not. My current system is just a line from each valve cover going to a dual inlet catch can from allstar(http://www.amsperformance.com/cart/A...mance.com.html). Just wanted to see what people thought about doing something like the picture below. This is on a Turbocharged 383
Old 10-18-2009, 12:58 PM
6 & 8 Second Club
mrdragster1970's Avatar
I don't like dumping that crap back into any engine. Especially not a N2O or boosted one.
I don't want any contamination in my charge. I'm not a turbo expert,
but it might be worth a vacuum pump. If it's too much, at least try an evac kit.
Check jegs or summit and you can get some ideas & pricing.
Old 10-18-2009, 12:59 PM
Thats why I would using a breather/seperator tank to seperate the air from the oil so the oil wouldn't go back into the engine. My thinking could be incorrect though.
Old 10-18-2009, 02:10 PM
I also am thinking about using a lt1 electric smog pump hooking the inlet of the pump to the valve cover
Old 10-22-2009, 08:47 PM
KOOSWS6's Avatar
Unhappy Venting
I am having some of the same issues with too much crankcase pressure. Does venting the valve covers help with crankcase pressure? How do the gases get up there, through oil passages? Is there a better way to vent the block?
Old 10-22-2009, 11:06 PM
LS6427's Avatar
Yes, if you put a breather/filter on the valve cover ports or an oil fill cap breather/filter you will eliminate any crankcase pressure from building up anymore. The crankcase gases flow right up into the valve covers.
But you should still pull crankcase gases/moisture out somehow. External vaccum pump venting to the atmosphere....or using a catch can and the normal vaccum port on the intake.
Quick Reply: crankcase venting
