Will this work fine or do i need a different h/c
72 corvette 350 all stock except for a isky cam.
Im planning to swap to afr heads 180cc Heads cut til 60cc = 10:1
Edelbrock rpm air gap intake
MSD Ignition
and mating it all with the Isky cam
Type RR-265/272 Hyd rol. Intake: .485 lift/217º @ .050, Exhaust: .505 lift/225º @ .050, Lope center: 112º 1.5 rocker ratio"
Will this combo work for low to midrange power, shifting at 6000rpm max
or is the cam not suited for this build.
It has a 650cfm edelbrock carb? should i upgrade this also?
Give me some comments so i can make the final order
MSD Ignition
