Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
can someone help please
Old 12-06-2009, 06:28 PM
z28camaro1090's Avatar
Default can someone help please
I have a 97 yukon with the 5.7 vortec. Its been loosing antifreeze. Granted i just did the head gaskets maybe 10,000 miles ago. Today i brought it home and a puddle of antifreeze on under the truck by the rear of the motor on the passenger side. I can see it its all over the starter trans and oil pan. What would cause this? Freeze Plug. I am not to familar with the vortec motors. can someone help me please.. it snowed here now i dont have my 4x4 just 2 camaros lol..
Old 12-06-2009, 07:48 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, check to see if the heater hoses are in good shape.
Old 12-06-2009, 08:08 PM
Badass355ciz28's Avatar
also check the coolant nipple on the intake. could be leaking and letting the coolant run towards the back of the engine......... also check your heater hoses and back of the intake........
Old 12-06-2009, 09:38 PM
Jusst checked heater core hoses.. I can't see th other because it is dark now.. it is wet on the passenger side of the motor.. and it only leaks after the car is heated and cooled down
Old 12-06-2009, 09:42 PM
the cooland nipple is on the front passenger side of the intake usually the o rings rots away and it starts to leak
Old 12-07-2009, 08:25 AM
ok i know what your talking about.. I will check that when i get back home today from college. That thing was a pain in my *** when I did the head gaskets.I am going to look close again at the heater core hoses just to make sure
Old 12-14-2009, 12:45 PM
jmd
jmd's Avatar
Check to see if you can borrow/rent a cooling system pressure tester. That should help narrow it down.
Quick Reply: can someone help please
