crankshaft
crankshaft
Is the crankshaft of a 4 bolt block identical to that of a 2 bolt? Specifically, the rear of the crank, where it goes into the rear main seal. diameter is not the question, it is length. I am having issues with my clutch fork pivoting and hitting the pressure plate. Questioning if the crank is longer, therefore changing the pivot point.
