Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
4.3 to carbed 350
Old 10-06-2015, 02:24 PM
Cheston350smallblock's Avatar
Default 4.3 to carbed 350
i have a 2001 single cab 1500 with a 4.3 that im wanting to swap for a carbed 350 with a more than mild cam. other than motor mounts, trans, electric fan. what else would i need to have a clean good swap. the 350 is going to be rebuilt fully. i may could get vortec heads and intake if it would make the swap easier.
thanks
Old 10-07-2015, 11:06 AM
also will i be able to keep ac? use long tube headers? i cant find anything on the web over it.
Old 10-09-2015, 12:11 PM
v8sten's Avatar
this is a shot in the dark.
Try the stock 4.3 motor mounts before you buy anything. if not then look at transdapt mounts.
Id use a stock radiator and electric fan out of a newer v8 model
trans should bolt up but you may have to get a stand alone TCU. TCI makes them
all the front accessories should bolt up to the 350, including a/c
headers. good luck no one is going to make a specific header for this swap. just gunna have to find some that will work, or some to modify.
Old 11-05-2015, 06:49 PM
Tinbender59's Avatar
you will need to get a NON electronic transmission as well, that does have an electronic speedo or purchase an adapter. just a dumb question why do you want to go backwards in technology??
put a TPI 350 in it or put TPI on your 350 read this. http://forum.gmtruckcentral.com/show...T-ON-THE-CHEAP
it is awhole lot easer and nicer
Old 04-12-2016, 06:35 PM
mrich0908's Avatar
You could use a gen 3 ecm with your sbc . I do with my turbo 383.
Quick Reply: 4.3 to carbed 350
