572 block ?
572 block ?
Hi I have a 69 Camaro and so I am planning on an engine to put in it. Anyways is there any blocks that can be used to make a 572ci engine can I convert a 502 to 572?
To get an idea on your options, check out Nyes racing engines and shafiroff racing engines and look under pump gas bbc. These sites are the easiest to research. If you want to build it yourself, they sell the parts.
The 540, 555, 565 are pretty are more common builds.
The Dart block would be my first choice.
Here is a 555 Bill Hartley built I helped him with his block and rotator and he used the AFR 357 heads and up graded to a .904 roller lifter for more reliability
If you have F/B here is a link.
https://www.facebook.com/photo.php?f...type=3&theater
Sorry for not getting back to you guys, I have been swamped with projects, I do like the idea of dart block, I have some dart iron eagle cylinder heads, I think the iron eagles would go good for what I am doing.
Thanks
Thanks
