Oil pan for a BBC?
I dont know about BMR but with my AJE you can run any rear sump pan you want. I have a dry sump box pan on mine and no problems. I am almost positive the BMR is the same way. With the motor in the car it sits back and above the K-member with the AJE.
Here is the only shot I have of the k-member and the motor in it. The motor is sitting on the k-member and supported in the rear with that bar so we could set the motor in right. That bar is just for mock up, but it should give you an idea of what pan you can run.
