454 BBC Progress Pictures
Here's a few photo's of my modified K-Member. It's not sitting perfectly level on the engine stand so thats why it looks a little off. But all the measurements are good and everything is equal on both sides. I originally had half an inch between the K-member and oil pan. After I welded my new brackets on there I took a 5 pound hammer and made a little more clearance.
I'm going to get my trans Friday so I'm going to bolt everything up Saturday and get some pic's of the BBC in the car. Any thoughts or comments?
just want to make sure that just cause you center it on the subframe, that its in the center of the tranny tunnel, normally cars motors are offset some to the passanger side. So before you get to far, i would put the motor and tranny up in the car just as a test fit
Thanks for the replys. I'm getting my trans this Friday so I'm going to do a test fit this weekend. I've got about a 1/4 inch of adjustments I can make either way with the motor.
I haven't decided on the front suspension yet. I've seen one person put a 454 in and use the stock front suspension. It'll be one of those things I have to look at as I go since there isn't a blueprint on how to do this. But hey I'm having fun and can't wait to complete the project.
whats the specs on that 454? Im DIEING to build my 454! I gotta find a weakend i can yank it out and take it to the shop. Let me know what cam, heads, etc u used and any comments or numbers you might have. Awesome project.
