Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Whats the largest intake valve I can run?
Old 12-25-2007, 12:38 PM
foggedz's Avatar
Default Whats the largest intake valve I can run?
With a standard 350ci SBC bore and a 1.600 exhaust valve, what is the largest intake valve that can be run?
Old 12-25-2007, 02:31 PM
1989GTA's Avatar
Rule of thumb is 51-52% of the bore size. That would be in the 2.05 to 2.08 range.
Old 12-25-2007, 03:03 PM
foggedz's Avatar
IC, well the heads I was looking at had 2.08 intake valves. Do you know if there are any issures with that large of a valve not clearing a stock size bore? Or is it just that the flow of the heads will be hurt from not having as much area around the valve?
Old 12-25-2007, 05:40 PM
Ryan02SS's Avatar
The larger the bore the more the valve will be unshrouded and flow will be better. 2.08" is about the largest you want on a stock 4.000" bore.
Old 12-25-2007, 07:05 PM
In-Zane Moderator
ZONES89RS's Avatar
When you step up to a 4.125 bore then you can look into the 2.10 valves, big nasty, better have a bump stick to makem work.
Quick Reply: Whats the largest intake valve I can run?
