camaro motor swap
camaro motor swap
Hey im lookin for a camaro or a trans am and i found one of the v6 five speeds and i was wondering if a 350 SBC would fit into the car without ne serious complications...
Yea im gunna put a carb on it...but would it be the same as installing it into the v8 version...as far as mounting the motor...becuz i kno i have to make a conversion bracket to put a gen 1 in place of the lt1, at least thats wut i been told...
No, first you need to change your K-member to one from a LT1 car, after that you can use the stock LT1 mounts if you weld some 1/8" steel to the driver side mount so you can drill the 3rd hole, only 2 line up, the passenger side is okay. That or you can just buy the BMR SBC/BBC conversion K-member.
