Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
how much hp will this set-up make?
Old 02-29-2008, 12:20 PM
silvergta's Avatar
Default how much hp will this set-up make?
can anyone help me out with how much hp this set up will make?? trying to decide wheather to build this or throw in an lt1...
1987 gta 350 tpi, bored .30 over
3.23 gears
10.3:1 compression
holley stealth ram intake with airfoil
comp xtreme enery hydraulic roller cam: 224/230 duration, 503/510 lift
hydraulic roller lifters
comp magnum roller rockers: 1.6 ratio
double roller timing chain
torque converter: ~2500 stall
3" flowmasters (thinking of changing)
Edelbrock shorty headers
might be getting heads
I was also wondering if anyone had some suggestions on good compatable heads and cam. im looking for around 350 hp with the above set-up. I really want a good sounding cam, but i have tpi so i dont think the lobe seperation should be less than 112 degrees.
Thanks a lot for any help!
Old 02-29-2008, 01:16 PM
jmm98LS1's Avatar
You'll need to ditch the stock heads if you want any power out of it. My bud has a very similar combo in his 3rd gen, only with a 220/230 cam and heavily ported aluminum L98 heads. It's runs gooooood.....by my well calibrated butt-dyno, I'd say sneakin up on 400hp.
Old 03-01-2008, 10:05 PM
silvergta's Avatar
hey thanks for your input.
does anyone have any recommendation on heads and the best size cam to go with them? im not looking to spend much more than 1000 on heads. i heard edelbrock heads are no good... true?
Old 03-01-2008, 11:01 PM
Drumer919's Avatar
Patriot Performance heard are about 800 complete, they're decent.
Old 03-02-2008, 09:18 AM
Shawn @ VA Speed's Avatar
i've been using the brodix ik180's on 350's with great sucess,made over 450hp with them on a street 350 with flattops and a hyd roller,they cost around $1100.00,i'm a dealer for them,let me know if your interested.
Old 03-07-2008, 11:31 AM
silvergta's Avatar
i think ive decided to go with a 383. ill also be getting a roller cam (around 220 or 230 duration and around 530 lift), roller lifters and rocker arms, torque converter around 2500 stall, and heads. I am thinking about the brodix ik180's
