Need some Help.
Need some Help.
I am fixing to put some new 42lb fast injectors in my car. I am leaning towards this being the problem with my system running lean code. I am also going to put a new fuel pump .
My questions are What is a good fuel pump I can get. Also will I need to retune after these. My car has already been tuned once.
Also does anyone know how to get in touch with gomer?
LSX Mechanic
Check out http://www.hinsonsupercars.com/ or www.speedsouth.com for your tuning needs in Alabama. Support the shops that need it.
To answer your question, a plain jane Walbro should do the trick and yes you will need a retune once it's all installed. The car will probably run pig rich until it's tuned.
Quick question...I cant find a good fuel pump I wanna go with and money is kinda tight...And having a hurt arm isnt to good for working on a car right now...much less driving a 6-speed.
how long do you think I could hold off on a pump with 42lb injectors...car never gets driven except on weekends.
