Southern Members A regional forum for all our down South members.
will a t56 6 speed bolt to the back of a 400 sbc!!!!
Old 10-08-2007, 07:28 PM
kngkahious's Avatar
Default will a t56 6 speed bolt to the back of a 400 sbc!!!!
just like the title says.i want to know if it will bolt up so i can build a turbo coupe.
Old 10-08-2007, 08:12 PM
z2fast8's Avatar
if u get the right bell housing
i know a t55 from kaiser fit to my 400 in my 69
Old 10-08-2007, 08:46 PM
kngkahious's Avatar
what bell houseing do i need
Old 10-08-2007, 11:18 PM
zlover129's Avatar
Get the LT1 T-56
Old 10-09-2007, 12:08 AM
the_merv's Avatar
^^Yup..
Old 10-09-2007, 05:50 PM
kngkahious's Avatar
so if i get the lt1 t56 it will work,i guess i should also use the lt1 bell houseing.i was told it is a basic small block anyway and had the same bolt patteren.
Old 10-09-2007, 11:30 PM
blue98Z's Avatar
^^That's what I've also heard from a few people.
Old 10-12-2007, 10:37 PM
kngkahious's Avatar
so is this true,that lt1's have the same bolt pattern as a basic sbc.
Old 10-12-2007, 10:48 PM
blue98Z's Avatar
That's what I've heard and the lt1 t56 has a shorter input shaft than the ls1 t56.
Old 10-13-2007, 12:30 AM
zlover129's Avatar
LT1 = SBC with fancy ignition system, better heads that are reverse flow, and thats about it. So yea, LT1 6 speed and bellhousing will bolt right up
Old 10-16-2007, 08:16 PM
CHRIZ28's Avatar
Good info, looking into putting a T-56 behind a BBC, and found this seems to be the easiest way. Any special clutch or flywheel you have to buy?
Chris
Old 10-17-2007, 10:27 AM
slowandrichws6's Avatar
Originally Posted by zlover129
Get the LT1 T-56
i have heard the same thing
Quick Reply: will a t56 6 speed bolt to the back of a 400 sbc!!!!
