I really need your help guys! (value of modded SS)
I'm going to sell my car and I need you help! Here is a link to the car Please look at this car
It has 36,000 miles on it here is the list of money I have into it. Some prices are high as I bought the car in Alaska and many parts were shiped there also. But Would it be to low/high if I asked $25,000.00 foir this car?
ALL input welcome. What would you aks for it for a simi fast sale. Its going on ebay very soon?
Fire Suit SFI 3-2A/5 - TPP19.9 triple layer suit $350.00
Bogart Rims and tires $2,300.00
Concept Neeper Rims $1,200.00
Z rated front Nitto Rear $700.00
Strange Rear end $2,300.00
Heads $350.00
Cam $750.00
Nitrous System $800.00
NX Refill Station $1,000.00
Wires $100.00
Autotap $250.00
Direct Flow $175.00
STB $175.00
Tac $120.00
TQ Arm $450.00
LC Arms $200.00
PH Bar $125.00
LC Arm Re-low $140.00
KB DD Sub Frame $240.00
SLP Headers $1,200.00
Cut outs $75.00
Line Lock $125.00
McLoad Clutch $850.00
Wilwood Brakes $450.00
Roll Bar $575.00
Sway Bar $450.00
Belts $65.00
Radar Detector $400.00
Custom Paint $5,000.00
Speaker $300.00
Miss-Car Part $1,200.00
Car Cost $27,000.00
Total $49,415.00
2000 Camaro SS Build Number #534 ;-)~ 370 HP with 365 Torque, Black W/Blue Pearl & Ghost Flames, Port & Polished Heads, Ferrea Comp + Valves, Lunati 221/224 .558 .560@114, CC 941, SVO 30# Injectors, Bosch In Line Fuel Pump, NX-150 Wet, NX Purge, Fully Functional Custom Ram Air, 160 deg, NGK T6, Throttle Body By-Pass, Taylor Thunder Volt Wires, MAFT, Bosh Fuel Pump, AutoTap Mount Inside Car, K&N Filter, Direct Flow Lid, Edelbrock 3 Point Strut Tower Brace, Free Mods, Auto Meter 5 inch Tachometer With Shift Light, Spohn: Full Race Torque Arm, Lower Control Arms, Adjustable Panhard Bar, Lower Control Arm Relocation Brackets, Kenny Brown Double Diamond Sub Frame Connectors, SLP Long Tube Headers, SLP High Flow Y-Pipe, Off Road Pipes, Cut Outs, Line Locks, McLeod Street Twin Clutch, McLeod Master Cylinder, McLeod Slave Cylinder, Strange 12 bolt, Strange 35 Spin Axles, Strange Light Weight Spool, 4:10's, Coleman Aluminum Drive Shaft, 28"x10.5" ET Drags, 3.5" Skinnies, Bogart 15" Rims, 3.5" Wheel Studs, Wilwood Pro Street Brakes, Wolfe Race Craft Roll 6 point Bar, Wolfe Race Craft Rear Sway Bar, RCI Belts,
Heads $350.00
Cam $750.00
Wires $100.00
Autotap $250.00
Direct Flow $175.00
STB $175.00
Tac $120.00
TQ Arm $450.00
LC Arms $200.00
PH Bar $125.00
Cut outs $75.00
Line Lock $125.00
Roll Bar $575.00
Sway Bar $450.00
Belts $65.00
Speaker $300.00
Car Cost $27,000.00
Total $49,415.00
Re: I really need your help guys!
I can't tell from the pictures but what's custom about the paint job? I guess you probably know you'd do much better by taking the parts off and selling them separate...
The paint is black with blue pearl and blue pearl ghost flames. check here http://groups.msn.com/RichardsBruce/...p;PhotoID=1001
and here
http://groups.msn.com/RichardsBruce/...mp;PhotoID=486
and here
http://groups.msn.com/RichardsBruce/...mp;PhotoID=490
I really don't want to mess with taking it apart i'm not looking for the most but really the fastes sale.
and here
and here
u might get $18k for it... $350 for heads?? whats a NX refill station for $1000? u should also specify the wheel sizes and tire sizes, and rear gear, and cam size, and what was done to the heads...
yeah unfortunatlly you never get what there worth. i needed to sell my '01 z28 quick and only got 16500 for it. and it was putting 400 to the rear wheels. with a moser 9" heads and cam etc.... im not complaining. i bought her cheap but i put a lot into her and didnt get much out, i know this is true at least when it came to money, but fun, hell she was beyond compare.
The $1,000 is for the NX refill station. $350 for the heads was the valves, springs and instalation.
I will be giving more information when I have time. Right now I'm fishing for comments. Thanks
Patman I'm selling it to have a custom chopper built for me. I also have a check comming in for $30,000.00 back pay from the V.A. for my disability. My disability rating was increast from 60% to 80% and they owe me 6 years back pay. Its going to be a show bike and cost right at $40,000.00 to $50,000.00 to have built. The motor is a STD 145 that puts out up to 180 HP with 170-180 TQ. STD 145 Motor I'm checking on how much with a supercharger that should bring it up to around 280 HP. $10,000 to $15,000 for the motor and supercharger alone. So far we have hammered out the rake degree and overall length. It comes in at 9 1/2 foot long wheel to wheel maybe more. The forks alone are almost 5 foot long and will be inverted for strengh. It is going to be pearl white with 40% pearl red mixed in. Layered pearl flames. Starting with pearl red with pearl orange laid over that and then pearl yellow over that. The motor and supercharger will either be all chromed or flat black. 5 inch final drive (I'll get more info later today). There are to many details to list right now but it will take them (Mid West Choppers) about three months to build it and they will have to lengthen their build table to do it.
The fastest way to sell it is probably to take off everything you can (nitrous, wheels, tires, headers, firesuit, etc) and sell that stuff separate and then sell the car for whatever you can get ($20K max I'd guess). I've sold parts on here and you better to be ready to ship it when you do the post to sell it 'cause it'll move . Unfortunately, unless you run across somebody with the cash they'll probably have to finance it. I don't think a bank will care about what it's really worth.
Good luck.
Good luck.
