Strange and Moser rear end GP
Old 02-01-2010, 06:50 PM
Kaltech Tuning's Avatar
All requests to this point have been responded to.
Kaltech Tuning is offline
Old 02-01-2010, 07:32 PM
ABQ99TA's Avatar
Moser 9
1999 TA
4 channel
3.89
TruTrac
LCAs welded, Drive shaft to fit and TA mount
ABQ99TA is offline
Old 02-02-2010, 01:44 PM
All requests responded to.
Old 02-02-2010, 03:04 PM
00T/AWS6's Avatar
Strange 12 bolt and 9"
Don't need ABS or Trac Control
Aluminum center Spool
4.30 gears, Backbraced, Plugs
35 spline gun drilled axles
With moly DS and loop
LCA brackets welded on
00T/AWS6 is offline
Old 02-03-2010, 03:05 PM
Grifter's Avatar
PM sent.
Grifter is offline
Old 02-03-2010, 04:53 PM
nm2769's Avatar
Price on 9" with driveshaft please.
Year and model of the car - 2002 Camaro SS
ABS? 3 channel (no traction control) or 4 channel (with tcs) - 3 channel
Desired gear ratio - 3.90
Desired differential - Detroit locker and tru-trac please
Any additional options you know that you want. - LCA brackets welded on.
nm2769 is offline
Old 02-03-2010, 08:32 PM
kikass_z28's Avatar
s60 35 spline stock width
Year and model of the car- 1991 camaro
ABS? 3 channel (no traction control) or 4 channel (with tcs)- no
Desired gear ratio- 4.10
Desired differential- tru-trac
Any additional options you know that you want. - shortened driveshaft, welded on lca relo brackets, backing plates for 98-02 brakes, aluminum girdle cover, chrome moly pinion yoke
Will I need a conversion U-joint?
kikass_z28 is offline
Old 02-03-2010, 08:46 PM
Old 02-04-2010, 05:23 PM
JC70SS's Avatar
looking for Strange 12 bolt
3 channel
4.10 with eaton posi
33 spline axles
JC70SS is offline
Old 02-04-2010, 07:12 PM
Responses sent.
Old 02-10-2010, 10:22 AM
UrSmked's Avatar
quote on a 2000 trans am. 9 in. or S60, 4 channel, 4.11 gears, spool, narrowed 2.5" off each side, 35 spline. Price both please.
UrSmked is offline
Old 02-11-2010, 10:59 AM
  #32
MacGyver's Avatar
Moser 9"
99 Trans am
No ABS
3.70 Gears Nodular Center
35 spline spool
Fill and drain plugs
LCA brackets welded
Shipped to 32725
MacGyver is offline
Old 02-11-2010, 02:51 PM
  #33
+badss+'s Avatar
Year and model of the car 2002 camaro ss
ABS? 3 channel (no traction control) or 4 channel (with tcs) 4 channel
Desired gear ratio 3.73
Desired differential 35 spline with spool
relocation brackets welded on
12mm long studs
reusing backing plates
drain and fill
shipped to 32909
+badss+ is offline
Old 02-11-2010, 06:23 PM
  #34
PM's sent
Old 02-11-2010, 06:46 PM
  #35
quik01ss's Avatar
2001 CamaroSS
-Moser 12 bolt
3 Channel
4.11 Gear
31 Spline
Tru-Trac
Stock Length
Alum. Rear cover
Thanks
quik01ss is offline
Old 02-11-2010, 07:11 PM
  #36
LS1powerhouse02's Avatar
Strange 12 bolt
4.10 gears
Eaton posi
3 channel
LCA relocation brackets welded on
Rear girdle
and upgraded DS
for a 2002 Z28.
LS1powerhouse02 is offline
Old 02-11-2010, 09:22 PM
  #37
C0wb0y's Avatar
97 Camaro
No ABS No traction control
4.11 gear ratio
35 spool
Tru Trac
C0wb0y is offline
Old 02-15-2010, 11:03 AM
  #38
All requests and questions answered.
Old 02-15-2010, 05:55 PM
  #39
Franklin's Avatar
2002 Camaro SS 4 channel
S60, 4.10 gear, with LCA brackets welded on, Aluminum cover, truetrac
Franklin is offline
Old 02-16-2010, 12:15 PM
  #40
poopman's Avatar
12 bolt or s60
97 z
3 channel
4:10 eaton or true trac
welded lcas
poopman is offline
Quick Reply: Strange and Moser rear end GP
