Strange and Moser rear end GP
#68
Location: Your girl's back door giving her the long stroke while you're at work
Car is a 2002 Trans Am
Need a quote for 9", 12 bolt, and S60, all drive shafts for a TH350.
need direct bolt in with all mounts
NO TCS/ NO ABS
3.90 and 4.11 gears
tru trac or detroit locker
stock width with and without backing plates
fill/drain plug, lca relocation
Shipped to a business at 45694
NO TCS/ NO ABS
3.90 and 4.11 gears
#75
2001 Camaro m6
moser 9in
31 spline
4 channel
3.89 gear ratio
iron case and cost for aluminum
lca reloc brackets
trac-loc
drain and xtra fill plug
shipped to 60463
thanks in advance!
moser 9in
31 spline
4 channel
3.89 gear ratio
lca reloc brackets
trac-loc
shipped to 60463
thanks in advance!
#80
need a quote for a
2001 Camaro Z-28 M6
*S60
*4.10 Gears
*truetrac
*3-channel ABS
*need direct bolt in with all mounts
*driveshaft, lca reloc brackets, backing plates included
2001 Camaro Z-28 M6
*S60
*4.10 Gears
*truetrac
*3-channel ABS
