Strange and Moser rear end GP
#82
Strang and Moser rear end GP
2000 Formula A4
Moser 9" - Stock Width
No Traction Control
Backing Plates
3.73 Gear
Detroit Locker
35 Spline Axles
Reolcation Brackets
Drain & Fill plugs
To 27530 zip
No Traction Control
Backing Plates
3.73 Gear
Detroit Locker
35 Spline Axles
Reolcation Brackets
Drain & Fill plugs
To 27530 zip
#84
98 Camaro z28
Strange S60
Narrowed 3" per side
4 channel ABS/TCS
3.90's --(What brand gears are available? What ratios are available?)
Eaton TrueTrac --(What brand differentials are available?)
LCA relocation brackets welded on
E-brake cable mounting brackets welded on
Brake line brackets welded on
Does the housing come bare, or painted?
Shipped to zip 39402
Strange S60
4 channel ABS/TCS
#86
I would like a price on an S60.
2001 Camaro z28 M6
3 channel
4.10 gears with truetrac
stock width
35 spline axles
new backing plates
new drive shaft
welded LCA's
ready to bolt in
And does the S cover cost extra?
shipped to 98053
2001 Camaro z28 M6
3 channel
stock width
35 spline axles
new backing plates
new drive shaft
welded LCA's
ready to bolt in
shipped to 98053
#87
Quote on an S60 please
Year and model of the car - 99'
ABS? 3 channel (no traction control) or 4 channel (with tcs) - 4 channel
Desired gear ratio - 3:73
Desired differential - true trac
Any additional options you know that you want - relocation lca brackets welded on.
backing plates
new drive shaft
35 spline axles
shipped to 28348
backing plates
new drive shaft
35 spline axles
shipped to 28348
#92
Price on an S60.
2001 Camaro M6
4 channel
Stock width
35 spline axles
New backing plates
Aluminum cover
New drive shaft
Welded LCA's
Ready to bolt in
Shipped to 77546
Thanks,
Jim
2001 Camaro M6
4 channel
Stock width
35 spline axles
New backing plates
Aluminum cover
New drive shaft
Welded LCA's
Ready to bolt in
Shipped to 77546
Thanks,
Jim
#94
s60
99 TA
35 spline
tru trak
3.73
4 channel
new backing plates / reluctors
stock lugs
All new mounts and brackets for the Fbody
4l60e compatible drive shaft capable of holding as much power as the rear will
99 TA
35 spline
tru trak
3.73
4 channel
stock lugs
#100
Hi,
Looking for the following:
Moser 9" full spool for 2001 trans am, stock width
Standard Finish
35 Spline Axles
4 Channel
3.75 Gears
Drain Plug
Stock Style sway bar brackets welded on
Standard Axles
Stock wheel stud's
NO back-brace
Also would be looking for a driveshaft, 3.5 PST for an M6, or similar.
Looking for total out the door price shipped to central NY (13090)
Thank you in advanced...
--Mike
Standard Finish
35 Spline Axles
4 Channel
3.75 Gears
Drain Plug
Standard Axles
Stock wheel stud's
NO back-brace
--Mike
