HPE cam specials
Old 10-14-2009, 10:31 AM
Austin@HPE's Avatar
Default HPE cam specials
Horsepower Engineering will be offering a cam special from now until the end of November. The cam kit will include a Comp cam, Manley springs, pushrods, install and the tune.
Camaro, GTO will be $1450.00.
C5/C6 Corvette's, 2010 Camaro/G8 gxp LS3 will be $1650.00. (C6Z06 $100 more)
Optional items to be added
LS3 Oil Pump $150.00
Double Roller Timing Chain $109.99
Install t/c & oil pump $50.00
G8/2010 Camaro L99 DOD delete cam kit $2650 installed and tuned
HPE stage 1 square port cam
GM LS7 Lifters
GM Balancer Bolt
GM LS2 Valley Cover
GM LS7 Camshaft Sprocket
GM Valve Cover Breather Block-Off
GM Header Gasket
GM Ls2 Timing Chain Dampner
GM PCV hose for non-DOD applications
GM LS2 Lifter guide kit
GM Camshaft Retainer plate bolts
GM Timing Chain Bolts
ARP Head Bolts
GM MLS Head Gaskets
.650 lift dual valve springs
Chrome Moly pushrods
Oil Change Mobile 1 oil
Install heads at the same time add $600.00, this will include head gaskets, stock head bolts and the oil & filter.
LS6 Heads Stage II $1250.00
Trickflow Heads $2300.00
LS3/L92 stage 2 heads $2050.00 G8's/l99 free install with purchase of g8/l99 dod delete cam kit installed.
All heads have springs installed. $250 will be subtracted from cam kit if heads are purchased to be installed.
Please call to schedule your install.
11950 Perry Rd. Ste. G
Houston, TX 77064
281-477-3100
Old 10-27-2009, 09:12 PM
Austin@HPE's Avatar
Come on guys we have had a good response so far. Lets keep it going.
Old 10-28-2009, 10:46 AM
Restricted User
FMS_FTW's Avatar
pm sent
Old 10-30-2009, 10:12 PM
Austin@HPE's Avatar
We Have a deal for the next two dod delete kits installed were offering $250 off that makes it $2400 we had 5. Already did 3 so next 2 get a deal. We have two different cams for these cars with out fly cutting our x and xx. The xxx requires stroker motor with valve relief to really use to full potential.
Old 11-04-2009, 04:04 PM
Austin@HPE's Avatar
bumb for good weather
Old 11-23-2009, 11:11 AM
Restricted User
FMS_FTW's Avatar
Thanks guys for the new updated cam instal. I hate bing.
Quick Reply: HPE cam specials
