**Pavlock Performance Stage 2 Street Assassin Package!**
Old 10-28-2009, 10:48 AM
Pavlock Performance's Avatar
Default **Pavlock Performance Stage 2 Street Assassin Package!**
For a limited time we are providing significant savings on Our H/C Packages.
This package consists of our hand ported/flow tested heads and Cam Kit if you chose Package 2. Each port is within 2cfm of each other unlike a lot of the CNC heads that we have had on our flow bench.
PACKAGE 1:
-Stage 2 Street Assassin Head
-2.00/1.57 GM Valves with Custom Valve Job
-.660'' Double Valve Spring with Titanium Retainers
-GM MLS Head Gaskets
-GM Head Bolts
-LS7 Lifters
-Ls2 Lifter Trays
These heads will flow between 300-310 cfm and will come fully documented with a flow sheet for every runner. Our heads have ZERO turbulence through .900 lift!!
All for only $1986.00 plus shipping.
+175.00 for 2.02 Valves
The heads will flow around 10-15 cfm additionally over the 2.00 Valve
PACKAGE 2:
-Custom Comp grind Tailored to your exact flow numbers.
-Chrome Moly 7.400 push rods
-GM Timing Cover Gasket
-GM Crank Seal
-GM Head Bolts
-LS7 Lifters
-Ls2 Lifter Trays
All for only 2535.00 Plus Shipping!!
This particular Car made 414rwhp Through a 3600 Stall, Stock unported manifold, 3.23 Gears and maxed out injectors!
Numbers to come next week with ported FAST 92/92, 30LBS Injectors, and 3.73 gears
Old 10-29-2009, 08:49 AM
Ruckus46Gt's Avatar
what casting are the heads?
Old 10-29-2009, 10:09 AM
241 For Fbodys. But we also have a package for ls3's
Old 11-03-2009, 08:21 AM
Just finished this complete car from a shell to a running car in 15 hrs straight! Very tired but well worth the results.. This is a nitrous cam spec that runs well on motor (dyno is all motor, no gas yet), Street Assassin Head package, FAST, going through a 9 inch!! Enjoy!
http://www.youtube.com/watch?v=hzMMPNFY-2M
Quick Reply: **Pavlock Performance Stage 2 Street Assassin Package!**
