**EFI-Live Scan & Tune w/LC1 Special**
EFILive - The most complete tuner on the market today. Tune you LS1,LS2,LS3,LS7,LS9 vehicles at home or you can also opt for a Ragin Racin Tune to get you going with our support. We have found that EFI Live has kept up with the market and is ahead of the curve with its tuning software. This is why we are bringing this software to you.
EFI Live includes everything you will need to tune your LSx vehicle properly.
Special Pricing - $799 w/free shipping for the V2 & Scanner
Add in a LC1 Wideband - $899 w/Free Shipping.
Ragin Racin Tune w/purchase - $100
FlashScan V2 Package Contents
FlashScan V2 interface device
EFILive Scan and Tune software installation CD
8 x AD-2 external input connectors
EFILive OBDII cable (J1962-A to RJ45)
EFILive USB cable (USB-A to USB-B)
EFILive RS-232 Serial cable (DB9 to RJ12)
FlashScan V2 is a standalone OBDII vehicle scan tool and data logger plus a pass through device that connects a laptop computer to a vehicle for scanning, data logging and re-programming onboard controllers.
This product contains 2 VIN licenses. You can tune any 2 engine controllers and any 2 transmission controllers with those 2 VIN licenses. To tune more controllers than that, you must purchase additional VIN licenses or unlimited stream licenses.
FlashScan V2 supports the three major OBD protocols used by GM vehicles:
OBDII CAN for scanning, data logging, reading and re-programming most 2006 and later model years.
OBDII VPW J1850 for scanning, data logging, reading and re-programming most 1996 to 2005 model years.
OBDI ALDL for scanning and data logging most 1995 and earlier model years.
This protocol is not available yet. When it is available, it will be a free update for all EFILive FlashScan V2 customers.
The LC-1 Lambda cable is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1 & LM-2, and includes digital input, output, and 2 user programmable analog outputs. (View Video) The LC-1 is more accurate than conventional designs costing many times as much, and its self-calibrating circuitry can compensate for changes in temperature, altitude and sensor condition. The LC-1 is ideal for applications such as Dynos, Data Acquisition, Standalone ECUs, piggyback fuel controllers, OBD-II software or chip programmers, and gauges. With the LC-1, you can add additional wideband channels to your LM-1, convert an existing narrow-band gauge, or add wideband capabilities to your dyno. You can even tune individual cylinders by using multiple LC-1 kits.
Please give us a call to place you orders. EFI Live is in stock and ships within one day.
