*new erl sleeved ls 454 short blocks only $5000.00*
ERL LS DRY SLEEVE 454CI SHORT BLOCK
The ERL LS Dry Sleeve Short Block provides up to 454 Cubic Inches for $5000. The dry sleeve system replaces the stock cast iron sleeves with high strength ductile iron sleeves. These sleeves are made of ductile iron that is 3 times stronger than cast iron. The ERL sleeves are significantly longer and thicker than stock sleeves, this allows for up to a 4.125” stroke and a 4.185” bore.
Each short block is blueprinted and built to the same exacting standards as our 2000HP race engines. Every short block comes with high quality components such as Wiseco pistons with GFX rings, Compstar rods, and Compstar crank. This is an economical package well suited to Applications between 600HP and 800HP. Packages are available for both Naturally Aspirated Applications and Boosted Applications.
SHORT BLOCK FEATURES
* Fully Blueprinted Short Block
* ACL Race Bearings
* Forged 2618 Pistons from Wiseco
* Billet 4340 Compstar H Beam Rods
* Compstar Forged Crankshaft
* Hand Honed Deck Surface
These new short blocks are priced at 5000.00 for the fully assembled short block. The price is with you providing a good LS2, LS3, LS7 or LS 5.3 block for us to sleeve. Please call if we can get one of these built for your next setup.
* ACL Race Bearings
We've done it for the LS1 but it has to stay around stock bore size. The reason we really can't do the same thing to an LS1 is because the in the LS1 the sleeves aren't siamese together and they have a water jacket in between them. We can take your LS1 and sleeve it using our ERL Superedeck I system and it would only run you 6500.00 and that includes the same rotating assembly, ERL doweled billet main caps and our Superdeck I system. It's a very reliable short block. Click here to look at our Superdeck I sleeving: http://www.erlperformance.com/gm-ls-...-block-sleeved
