****Mickey Thompson Drag Radials!!!!!!!****
Old 03-05-2012, 10:16 AM
Ryan@RPM-Motorsports's Avatar
Default ****Mickey Thompson Drag Radials!!!!!!!****
ET Street Radial
Worlds Fastest Street Radial!
Mickey Thompson's legendary race tire technology comes to the street with the ET Street Radial. Built using the latest in high tech radial construction techniques and years of drag racing experience and compound development, this D.O.T. approved street legal drag radial will get your car down the track in record time and drive you home with sure handling and an excellent ride.
■Soft Compound For Superior Traction On The Drag Strip
■Radial Construction for Excellent Ride Control on the Street
■Low Void, Directional Tread for Maximum Dry Traction
■Special Sidewall Construction for Quick Launches.
CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle.
All Mickey Thompson ET Street Radial tires are designed for drag racing use. While Mickey Thompson ET Street Radial tires meet Department of Transportation requirements for marking and performance, they are recommended for DRY PAVEMENT USE ONLY.
MT3752R 235/60R15-----$193.00
MT3753R 275/50R15 26 X 11.50R15-----$189.00
MT3756R 255/60R15 27 X 10.50R15-----$190.00
MT3754R 275/60R15 28 X 11.50R15----- $202.00
MT3757R 325/50R15 28 X 13.50R15-----$209.00
MT3762R 295/65R15 30 X 12.50R15-----$207.00
MT3763R 315/60R15 30 X 13.50R15-----$207.00
MT3793R 255/50R16 26 X 10.50R16-----$206.00
MT3743R 275/40R17 26 X 11.50R17-----$207.00
MT3755R 295/55R15 28 X 12.50R15-----$215.00
ET Street Radial II
Optimized For Modern Sports Cars & Sport Compacts
The ET Street Radial line is specifically designed for modern performance cars including spot compacts, Mustangs, Corvettes, Vipers and others that require bigger wheel diameters for brake clearance.
■Polyester Ply, Steel Belted for Strength and Durability
■D.O.T. Approved
CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle..
MT3730R 205/50R14 22X8.50R14-----$164.00
MT3732R 215/60R14 24X8.50R14-----$167.00
MT3750R 205/50R15 23X8.00R15-----$161.00
MT3751R 225/50R15 24X9.00R15-----$178.00
MT3794R 295/50R16 28X11.50R16-----$209.00
MT3740R 205/40R17 24X8.50R17-----$189.00
MT3744R 315/35R17 26X12.50R17-----$211.00
MT3745R 295/45R17 28X11.50R17-----$237.00
MT3780R 245/40R18 26X9.50R18-----$249.00
MT3782R 265/40R18 27X10.50R18-----$269.00
MT3785R 305/35R18 27X12.50R18-----$294.00
MT3788R 345/35R18 28X13.50R18-----$324.00
MT3786R 305/45R18 29X11.50R18-----$303.00
MT3723R 305/35R19 28X12.50R19-----$333.00
MT3727R 305/35R20 29X12.50R20-----$340.00
I can also offer low prices on micky thompson sportsman pro and front runners, just to name a few. Let me know a size and a model number and I will shoot you a price.
Any questions, give me a call
919-661-7947
ryanrpm1@bellsouth.net
Thanks Ryan
$19.95 shipping each per tire.
Quick Reply: ****Mickey Thompson Drag Radials!!!!!!!****
