DiabloFormula Racing New Sponsor Transmission Special
Old 10-20-2013, 08:16 AM
DiabloFormula's Avatar
Default DiabloFormula Racing New Sponsor Transmission Special
As a new sponsor here on LS1tech.com, DiabloFormula Racing would like to offer a transmission special till November 30th.
Our custom 700R4/4L60/65E builds consist of:
-Z-Pak 3-4 clutch pack
-Sonnex smart shell (stronger and better then the "beast shell"
-DFR custom shift kit for street, street/strip, or full drag.
-Pinless 1-2 accumulator (prevents leak by over the plastic or aluminum units)
-All new lip seals and/or molded pistons
-All new teflon rings
-High energy clutches though out the rest of the transmission
-29 element dual caged sprag
-DFR custom modified corvette servo
-High energy wide 2-4 band
-Machined reverse/input drum
-New Filter
-New gaskets
-New seals
-Hardened pump rings
-Sonnex TCC Update
-Aftermarket transmission cooler
$1650
Our T56 builds consist of:
-All new synchronizer rings
-Steel 3/4 fork
-New seals
-No walk tail housing bushing
-Bronze shifter cup (if desired)
-1-6 billet keys
-1-6 bronze fork pads
-Bronze input shaft bushing
-New retainer rings
-New brass reverse synchronizer ring
$1750
And the best part of this deal, prices include removal/install and fluid of the transmission!!
T56 rebuild will also include the install of any customer supplied clutch (if desired)
Prices apply to 93-02 F-body.
Call for slightly adjusted prices on Corvette, GTO, CTS-V G8.
Custom non billet and billet converters available as well, any stall from 2000-4200, discounted prices with trans build.
Old 11-03-2013, 11:46 AM
Less then a month left on this deal, if you're not local and send my your trans I can cut you an even better deal!!
Quick Reply: DiabloFormula Racing New Sponsor Transmission Special
