Summer Premium Synthetic Oil Special
Old 06-25-2004, 10:19 AM
Mr. B's Avatar
Default Summer Premium Synthetic Oil Special
1 Case (12 Qts) of Amsoil Series 2000 Synthetic 0W-30 Motor Oil
2 Amsoil Super Duty Oil Filters (for the LS1)
This will get you beyond the hot summer months, without worry that your motor oil is breaking down!
Specially Priced @ $109.88 for the Case of 12 QTS and 2 Super Duty Filters.
PAYPAL, Check & Money Order ONLY
PayPal Address: bbrand375@optonline.net
Some info about these products:
Race-proven technology designed for passenger car performance. Provides unsurpassed fuel efficiency and up to twice the wear protection provided by popular conventional and synthetic motor oils. Recommended for use in all vehicles requiring 5W-20, 5W-30 or 10W-30 motor oils.
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil is Recommended for Applications Requiring the Following Specifications:
API SL, SH, SJ, CF
ILSAC GF-1, GF-2, GF-3
ACEA A-1, A-2, A-3, B-1, B-2
Chrysler MS-6395 H
Ford ESE M2C-153G
GM 4718M, 6094M
US MIL L-46167B
VW 505.00, 501.00
Mercedes Benz AG 226.1
JASO VTW Spec.
Product Description
Passenger car and light-truck engines today are built for fuel efficiency and power. AMSOIL Series 2000 Synthetic 0W-30 Motor Oil optimizes efficiency and power without the sacrifice in wear protection that comes with many fuel-efficient, low-viscosity oils.
Testing shows AMSOIL Series 2000 Synthetic 0W-30 Motor Oil dramatically outperforms popular conventional and synthetic motor oils of much higher viscosity in wear protection (see chart).
Fuel Efficient Formula
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil efficiently transfers energy from the engine to the drivetrain. Its low coefficient of friction inhibits the energy loss to "drag" common to high viscosity oils.
Motorists seeking the ultimate in fuel efficiency may use AMSOIL Series 2000 Synthetic 0W-30 Motor Oil in place of higher viscosity motor oils.
High Temperature Protection
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil protects in high temperatures better than do the high-viscosity conventional and synthetic oils tested (see chart). Even after extended service in the engine, Series 2000 Synthetic 0W-30 Motor Oil maintains its ability to protect in high temperatures.
Low Temperature Protection
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil is specially formulated for superior cold temperature engine protection. Series 2000 retains excellent fluidity in extremely low temperatures, so it flows quickly and reliably to allow easy starting and immediate lubricating protection.
Motorists seeking cold temperature dependability and protection may use AMSOIL Series 2000 Synthetic 0W-30 Motor Oil in place of higher viscosity motor oils.
Heat Stability
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil is highly resistant to volatility. For example, in heat that causes conventional motor oils to lose as much as 25 percent of their mass, AMSOIL Series 2000 Synthetic 0W-30 Motor Oil loses less than ten percent.
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil's resistance to volatility keeps oil consumption extremely low and, more importantly, keeps the engine thoroughly lubricated and protected. Its resistance to volatility also helps keep fuel efficiency high and emissions low.
Clean Engine Formula
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil remains free of sludge, varnish and other by-products of high temperature degradation. With no deposits to foul them, engines stay cleaner longer for top performance and efficiency and maximum service life.
Shear Stability
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil is highly shear-resistant. With AMSOIL Series 2000 Synthetic 0W-30 Motor Oil's excellent viscosity retention, the protection that goes into the engine is the protection that stays in the engine, even over an extended course of severe service.
MIXING AMSOIL
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil may be mixed with petroleum-based oils or other synthetic oils. However, a mixture of AMSOIL Series 2000 Synthetic 0W-30 Motor Oil and another oil may offer a shorter service life than pure AMSOIL Series 2000 Synthetic 0W-30 Motor Oil does.
SERVICE LIFE
In personal cars and light-duty trucks with non-turbocharged gasoline engines: change the oil at 35,000-mile or one-year intervals, whichever comes first.
In turbocharged gasoline engines and occasionally used gasoline engines: change the oil at intervals up to three times longer recommended by the engine manufacturer or six months, whichever comes first.
In high performance and racing engines: specified by Owner Experience/Oil Analysis.
Marine four-cycle gasoline engines and infrequently used automotive four-cycle gasoline engines: drain oil at intervals up to three times longer than those recommended by the engine manufacturer, or one year, whichever comes first.
In fleet and industrial engines: drain oil at intervals up to two times longer than recommended by the manufacturer, or six months, whichever comes first.
AMSOIL Oil Filters should be changed at 12,500-mile or six-month intervals (whichever comes first) in gasoline engines. If a Hastings or other filter is used, filter should be changed at manufacturer's recommendation.
TYPICAL PHYSICAL PROPERTIES (revised 03/03)
AMSOIL Series 2000 Synthetic 0W-30 Motor Oil (TSO)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
11.2
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
56.9
Viscosity Index (ASTM D-2270)
195
Cold Crank Simulator Apparent Viscosity @ -35°C, cP (ASTM D 2602)
5520
Borderline Pumping Temperature °C (°F) (ASTM D3829) -40 (-40)
Pour Point °C (°F) (ASTM D 97)
-54 (-65)
Flash Point °C (°F) (ASTM D 92)
226 (439)
Fire Point °C (°F) (ASTM D 92) 247 (477)
Noack Volatility (DIN 51581) 250°C for 1 hour, % weight loss 8.6
High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683) 3.4
Four-Ball Wear Test (ASTM D 4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.374
Total Base Number
>11.0
Offer all-around better filtration and protection than conventional filters. Full flow design for extended drain intervals and severe service. Contains a high-tech blended filtration media composed of cellulose, synthetic and glass fibers. The media sets the Super Duty apart from conventional filters in capacity, efficiency and service life. Delivers superior filtration and protection.
PRODUCT DESCRIPTION
The AMSOIL Super Duty Oil Filter (SDF) is designed to provide maximum filtration while meeting the high flow demands of modern automobiles. The AMSOIL SDF contains a special cellulose, synthetic and glass blend media that offers the best possible balance of long life, high capacity and overall efficiency.
Traps Dirt Throughout Media Thickness
The AMSOIL SDF has a lofted fiber depth-type media that traps dirt throughout its entire thickness for exceptional filtering efficiency. It keeps oil clean and free of wear-causing contaminants. The AMSOIL SDF Oil Filter provides up to 100 percent more capacity and up to 20 percent greater efficiency than other filters provide. It is ideal for use with extended oil drain intervals.
Built for Rugged Performance
The AMSOIL SDF has a heavy-duty case of drawn steel. The case is double-crimped at the base with rolled-under seaming to withstand extreme pressure surges and road shocks.
Assures Oil Flow with Relief Valve
On most filters a relief valve is provided to assure ample oil flow. It prevents oil starvation in the engine in the event the media becomes saturated.
Prevents Oil Drainage During Engine Shutdown
On filter installations where the mounting is sideways or upright, dirty oil could drain out of the filter when the engine is shut off. The AMSOIL SDF has an anti-drainback valve that keeps trapped contaminants in the filter when the engine is not running.
APPLICATION
AMSOIL INC. recommends changing the AMSOIL SDF according to the following guidelines.
In gasoline-fueled engines using any AMSOIL motor oil except AMSOIL XL-7500 Synthetic Motor Oil, change the filter at 12,500-mile or six-month intervals. In gasoline-fueled engines using AMSOIL XL-7500 Synthetic Motor Oil, change the filter at 7,500-mile or six-month intervals. If a Hastings or other filter is used, filter should be changed at manufacturer recommendations.
In diesel-fueled large truck engines, change the filter(s) at the engine manufacturer's recommended oil change interval. In diesel-fueled light trucks, including pickups and vans, change the filter at 7,000-mile or six-month intervals.
When using an AMSOIL Oil Filter with conventional motor oils, refer to the owner's manual for the recommended oil filter change interval.
