Evans Pumps back in stock
Old 07-28-2004, 01:07 PM
Nasty N8's Avatar
Default Evans Pumps back in stock
Evans Cooling Systems Inc has just released More of there highflow LS1-6 water pumps. We finally got some new castings from GM. I will have them back in stock in about a week.
The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficiency in modified LS1 Corvettes, Camano’s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce parasitic horsepower loss at high RPM. A new serpentine belt is required.
pics
https://ls1tech.com/forums/attac...tachmentid=3364
https://ls1tech.com/forums/attac...tachmentid=3363
Evans complete new water pump with billet pulley $469.95 for Corvettes
Evans complete new water pump with billet pulley $469.95 for F-Bodies
Rebuilt GM pump with all new internals $399.95 and $125core charge
Add $125 for ceramic thermal coating-for extra heat dissipation and a little bling
Goodyear serpentine belt $49.95
Evans superflow 160* T-Stat $49.95 with purchase
Evans NPG coolant $22.50 a gallon
Evans NPG+ coolant $22.50 a gallon
Also Evans new NPG R race coolant in stock $19.50 a gallon
Or buy by the case(4)
Have a good day Nate
Old 07-28-2004, 01:14 PM
Pewter'00Z28's Avatar
Linkys no worky
Old 07-28-2004, 05:25 PM
1QUIKWS6's Avatar
I can personally vouch for the quality of the Evans pump and that they perform just as described.
I purchased one from Nate couple months back with the ceramic thermal coating option. It's being used on my 2K WS6 TA with 426rwhp/418rwtq - H2O temps hover around 185-190 deg max (and that is with Dexcool) no matter how hard I get on it.
And the coating/billet pulley definitely looks nice at the shows. I was going to opt for a bigger rad but after the addition of this pump I found I didn't need one!
I might add that this is even with the ASP UD Crank Pulley.
BTW Nate, you wouldn't happen to have a new, or slightly used 4L60E tranny built to at least Stage4 specs lying around that you want rid of? Or maybe a Strange rear with 3.73's/backing plates/3ch ABS - no traction control?
-Jay-
Old 07-28-2004, 07:02 PM
Nasty N8's Avatar
MMN nope but I can get them for you
Nate
Quick Reply: Evans Pumps back in stock
