*Special* TTP Built & Installed Motor Packages
Let us prepare your car during the winter months for the ultimate street/strip machine for the spring. Here are some of our installed packages:
All of our turn-key packages include the following:
Installation:
- Remove & Reinstall Motor/Trans
- Remove & Reinstall Top End Motor (Heads, Intake, etc.)
- Remove & Reinstall Bottom End Motor (Oil Pan, Camshaft, etc.)
- Install any clutch or torque converter combination is included.
LS1 Edit Full Custom Dyno Tuning
All fluids (Oil, trans, brakes), gaskets and filters necessary.
All motors include 1 year/15,000 mile naturally aspirated guaranteed labor warranty. Power adders such as superchargers, turbochargers, nitrous, etc. will void such warranty.
Installed Options:
- TTP Stage 3 AFR 205cc CNC Heads (Assembled with Dual Springs, Titanium Retainers, Spring Seats, Valve Stem Seals): $2182
- TTP V.2 Equalizer Camshaft: $430
- TTP Hardened Chromoly Pushrods: $105
- Rollmaster Double Roller T/C: $125
- GM LS6 Oil Pump: $90
- SVO 30lb Injectors: $275
- LSX 90mm Intake Manifold: $825
- FAST 90mm TB for F-Body: $450
- TPIS 90mm TB for Y-Body: $650 + Core
- SPEC Stage 3 X-Pad: $400
- SPEC Stage 3 F-Pad: $510
- SPEC Steel Billet Flywheel: $225
- SPEC Aluminum Flywheel: $360
*Note: Any package can be completed with hi or low compression pistons, inquire within for pricing.
TTP Stage I 348ci Magnum Package:
Parts:
- Crower 6.125" Rods
- Diamond Forged Flat Top Piston (-2cc Valve Reliefs - Stock C/R)
- Nitrate/Heat-Treated Stock 3.622 Crankshaft
- Federal Mogul Rod + Main Bearings
- Clevite Cam Bearings
- Diamond Pro Select File-Fit Rings
- ARP Main Stud Kit
- Included is also honing the block to 3.905" bore, cleaning, balancing, and assembly.
$4699.95 Turn-Key
TTP Stage II 348ci Magnum Package:
Parts:
- Lunati Pro-Billet 6.125" Rods
- ARP Main Stud Kit
$5249.95 Turn-Key
TTP Stage III 347ci Equalizer Package:
Parts:
- Lunati Forged 4340 Crankshaft
- Lunati Forged Flat-Top Pistons (-2cc Valve Reliefs)
- Lunati File-Fit Rings
- ARP Main Stud Kit
- Included is also honing the block to 3.903" bore, cleaning, balancing, and assembly.
$6049.95 Turn-Key
TTP 383ci Equalizer Package:
Parts:
- ARP Main Stud Kit
$6249.95 Turn-Key
TTP 395ci Equalizer Package:
Parts:
- ARP Main Stud Kit
$6249.95 Turn-Key
TTP 427-448ci Equalizer Package
- Darton MID Wet-Sleeved Block
- SCAT Forged 4340 Crankshaft
- Diamond Custom Flat-Top Pistons (-2cc Valve Reliefs)
- ARP Main Stud Kit
- Included is also honing the block to correct bore, stress relief, decking, cleaning, balancing, and assembly.
We can achieve up to a 4.160" bore for these combinations:
4.125" Bore x 4.000" Stroke = 427ci
4.125" Bore x 4.125" Stroke = 441ci
4.160" Bore x 4.125" Stroke = 448ci
$11599.95 Turn-Key
Installation:
Installed Options:
Parts:
- ARP Main Stud Kit
$4699.95 Turn-Key
Parts:
- ARP Main Stud Kit
$5249.95 Turn-Key
Parts:
- ARP Main Stud Kit
$6049.95 Turn-Key
Parts:
- ARP Main Stud Kit
$6249.95 Turn-Key
Parts:
- ARP Main Stud Kit
$6249.95 Turn-Key
- ARP Main Stud Kit
$11599.95 Turn-Key
