HPE Stroker Rotating Assemblies Special through Feb.
Old 02-06-2005, 02:29 PM
racer7088's Avatar
Thumbs up HPE Stroker Rotating Assemblies Special through Feb.
After building many extremely fast and reliable LSx based engines I have put together our own Eagle crank stroker kits here at HPE. These are all premium parts and can stand up to extreme usage and power. We have made nearly 600 RWHP NA with these kits and even much much more with power adders. Both the Wiseco and the Mahle pistons in these kits are excellent products and for the rest of February they will be on sale for 2099.00 unbalanced or 2199.00 balanced.
These rotating assemblies have:
- 4.000 4340 LS1 crankshaft
- 6.125 4340 H-Beam Rods
- Wiseco or Mahle Pistons depending on App.
- Wiseco or Mahle Plasma Moly Rings
- Federal Mogul 152M Main Bearings
- Clevite CB663H Rod Bearings
We will also be selling some "Econo" LS1 stroker kits that are intended mostly as NA kits or only with small power adders. These kits are somewhat more limited due to piston choices but are also very good deals if you do not need the extreme strength our regular premium kits have for engines making 600hp and less. These are being offered at 1899.00 unbalanced and 1999.00 balanced.
- 6.125 4340 I-Beam Rods
- Probe or Speed-Pro Pistons depending on App.
- Probe or Speed-Pro Plasma Moly Rings
Some 4.125 bore kits may add 75.00 to the total. We also offer custom piston upgrades for 200.00 and a Hellfire NOS upgrade on some pistons for 50.00 extra. All kits are mocked up here at HPE and all clearances are checked on these kits even without balancing including pin clearance and counterweight to piston clearance in our own mockup blocks so you won't have ANY surprises when you get them. Having assembled my own stuff at home in the old days I know how it is to not have any way to fix something in your own garage! On some kits however you may need to slightly notch the bottoms of the cylinders for rod bolt clearance although even on most 4.000 inch kits we do not have to. All the above kits use zero to only .015 offset rods and NOT the regular high offset SBC rods that many use. Feel free to email me any questions you may have or call after 1:30pm Central and ask for me personally.
Old 02-08-2005, 09:11 PM
racer7088's Avatar
To The Top.
Old 02-19-2005, 01:44 PM
racer7088's Avatar
Thumbs up
TTT one more time. We still have another two weeks to go and thanks for the business on the kits we have sold. Feel free to email or IM me for any more information. I do check for them every day or call after 2pm Central and ask for Erik here at HPE.
Old 02-23-2005, 01:19 PM
RealQuick's Avatar
Any LT1 stuff?
Old 02-23-2005, 03:04 PM
racer7088's Avatar
Thumbs up
Originally Posted by RealQuick
Any LT1 stuff?
Yes we do a lot of LT1/LT4 rotating assemblies. They are usually less expensive due to the crankshafts and more readily available pistons. Most are around 950.00 to 1575.00 or so depending on parts used. We balance again on most of these for 150.00 usually but I will do 100.00 for this sale. Email me if you need any more info.
Old 02-26-2005, 10:12 PM
11 Second Truck Club
2bseen's Avatar
What about a 6.0 iron block 408 kit?
Old 02-28-2005, 08:27 AM
BradWS6's Avatar
I'd like a price too.
Old 02-28-2005, 02:47 PM
racer7088's Avatar
Thumbs up
These are the same kits and they are 8cc Wiseco Pistons that give right at 11 to 1 at 65cc chambers. These are exactly what we run in all our own 408s. I will include balancing on these for the next two days or through wednesday for 2099.00 since I do have these items in stock right now.
