LS2 Wire Harnesses are ready!
Tenured Member
We have our LS2 Harnesses done. These enable you to use the LS2 engine, but run the LS1 ECM. We have them with LS2 and LS1 style injector connectors. Price is $475 Please call with questions-
Jim Hall
TPIS
952-448-6021
Jim Hall
TPIS
952-448-6021
wrencher
GM knock sensors have been the same output signal for ever. I dont thing the LS2 is any different. You be amazed at what it takes to get the knock sensor to move off of the 2.5 volt norm.
Like a hammer hitting the block-hard. I dont think there is really that much difference in detecting knock from the center or the outside of the block.
DO you have the injector plugs for sale only? I have some injectors that I was going to use that have the USCAR connector instead of the standard Jetronic connector.
http://www.redpulsar.us/~coldfusion/injectors.html
Thanks,
David
Thanks,
David
