February Nitrous Specials!!!
We know that its hard to stretch your income tax refund as far as your wants and wishes. So here at Nitro Daves we have put together many different packages to help it stretch alittle further.
These specials are good until the first March.
You will need to call your order in at 1-866-648-7637
Group 1
Our Custom Dry GTO Halo system..
GTO Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
NX automatic bottle heater,purge,fuel pressure safety switch,nitrous pressure gauge,NHRA valve and blow down tube.
Our Trick digital window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
NGK TR6 Spark plugs...
Special price 859.00
Group 2
Our Custom Dry F-body Halo system
F-Body Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
Group 3
Our Single Nozzle Dry System
Group 4
Our Dual nozzle Dry system
2 Dry nozzles,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings,hoses and hard ware.
Our Trick Digital Window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
Special price 825.00
Group 5
Nitrous Express single nozzle wet system
NX complete stage 1 EFI system
Special price 959.00
Group 6
Our Custom LS1 plate system...
Your choice of stock or 90mm.
billet plate,o-ring gasket,throttle extention bracket,jetting from 50-200,10lb bottle with 45 valve,stainless steel quick release bottle brackets,300 hp lifetime warrenty solenoids with purge port desighn,all mounting hard ware,hoses and fittings..etc
Special price 1,075
Group 7
Our Famous Dual nozzle special..
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.10lb Bottle With NXs 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value)
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Group 8
Misc Discounts
1.BMN window switch with first gear lock out... 100.00 while supplies last.
2. All of our dedicated fuel systems have 40.00 off...
3.10 percent off our custom console switch panels and solenoid brackets.
Thank you for all your support.
Dave
Group 1
Group 2
Group 3
Group 4
Group 5
Group 6
Special price 1,075
Group 7
Group 8
Misc Discounts
Dave
Originally Posted by M6WS6
Any deal with the Dual nozzle kit, no bellows but window switch with first gear lock out and WOT switch?
Dave
