McLeod Twin Disk Clutch Group Purchase!
We are running a group purchase for the McLeod Twin Disk clutch assemblies. 6 or more orders are required by Friday, May 5th for this to go through. The first batch will be ordered when the minimum is met so it will be benefical to place your order early. That can be done online or by calling 1-877-482-9763. Pricing is lower than we are allowed to advertise so you will need to give us a call to receive a quote.
F-body part numbers are -
LT1 -
64022-1A-07 Street Twin clutch assembly with steel flywheel
64022-00-07 Street Twin clutch assembly with steel flywheel - zero balanced
63022-1A-07 Street Twin clutch assembly with aluminum flywheel
63022-00-07 Street Twin clutch assembly with aluminum flywheel -zero balanced
LS1 -
64050B-00-07 LS1 Twin Disk Assembly with steel flywheel
63050B-00-07 LS1 Twin Disk Assembly with aluminum flywheel
Have a good day!
LT1 -
LS1 -
Have a good day!
