New FFHP Install Specials
We will be offering new install specials here at FFHP starting today; we will offer a different special every month starting on the 1st(except this one), the install appointment needs to be made during the months special and the install performed with in 30 days.
The first special will last from today until Aug. 30, 2006 and is a Custom Cam Package Deal
LS1 F-Body Package includes:
Custom Cam
Patriot Dual Spring Kit
Hardened Push Rods
New Crank Bolt
Water Pump Gaskets
Front Cover Gasket
Front Cover Seal
Oil Pump O-Ring
New Oil and Filter
New Coolant
Installed
Dyno Tuned
$1499.99
LS1 Y-Body Package:
Custom Cam
Hardened Push Rods
New Crank Bolt
Water Pump Gaskets
Front Cover Gasket
Front Cover Seal
Oil Pump O-Ring
New Oil and Filter
New Coolant
Installed
Dyno Tuned
$1699.99(not a corvette tax, cam installs are just more involved on them)
Thanks!
FYI- I can do a custom grind from Comp or get you one of the more popular cams from Thunder or TSP
Custom Cam
Hardened Push Rods
New Crank Bolt
Water Pump Gaskets
Front Cover Gasket
Front Cover Seal
Oil Pump O-Ring
New Oil and Filter
New Coolant
Installed
Dyno Tuned
$1499.99
LS1 Y-Body Package:
Custom Cam
Hardened Push Rods
New Crank Bolt
Water Pump Gaskets
Front Cover Gasket
Front Cover Seal
Oil Pump O-Ring
New Oil and Filter
New Coolant
Installed
Dyno Tuned
Thanks!
