Serious alarm question?
Old 10-16-2008, 11:58 PM
nitr0racing21's Avatar
Default Serious alarm question?
I lock my car and it goes through the lil beep beep to say its locked then 10 second later it goes !BEEP! !BEEP! and I dont know why
Old 10-17-2008, 12:00 AM
13lu91rS's Avatar
mine just started doing the same thing =[
Old 10-17-2008, 12:14 AM
Its so fricking annoying
Old 10-17-2008, 12:42 AM
Stocktonz28's Avatar
Im guessing the remote could be dirty. Therefore it might be sticking.
Old 10-17-2008, 07:23 AM
Ungrounded Moderator
WhiteBird00's Avatar
The most common cause of that problem is the shock sensor. You can try turning down the sensitivity but most people find that they have to disconnect it to get the problem to go away. Then you can either leave it disconnected or replace it - P/N 10444928, about $43 at the dealer.
Old 10-17-2008, 08:17 AM
So could it be my headlight vibrating the whole car?
Old 10-17-2008, 08:20 AM
No, it is probably just a defective sensor. They tend to get moisture in them and over time they will get bad enough to cause the alarm to stop working properly.
Old 10-19-2008, 09:09 PM
thecobrahunter's Avatar
I found that if I left any loose change in my ashtray, that would set off the motion sensor. I had to turn down my motion sensor almost all the way down.
Old 11-08-2008, 11:57 AM
texasglock23's Avatar
I'm having a problem
Today I noticed a low rear tire so I ran up the street to add more air. Didn't fool with anything at all other than that I came right back home. I started fooling around the house with chores and managed to hear my alarm. Ran outside and sure enough the horn was blasting. Neighbors were out ao I knew no one had fooled with it. It had just began to rain (small shower). I disarmed and re-armed the car. Within 15 seconds or so it began again. Repeated the same procedure and damned if it didn't go off again. So I just locked the car from inside and it started going off after that. So as of now I just left in unlocked.
Info on the car: Bought the car about 3 months ago max. Done nothing to it as of yet. It has rained the laste few weeks, and right after buying the car. Never have I had this problem before. Can anyone chime in and help me?
Old 11-08-2008, 12:17 PM
13lu91rS's Avatar
yea just lower the sensitivity on your shock sensor..
its the little **** on the black box by your spare tire
Old 11-08-2008, 12:29 PM
I actually did that...didn't seem to help. Next step is to unplug the bastard.
Old 11-08-2008, 12:32 PM
13lu91rS's Avatar
thats what i did.. cause it had the problem up there ^^
i would set it, then it my alarm would go of BEEEP BEEEEP then stop. and it got annoying trying to get into the house without waking up every1 real late
Old 11-12-2008, 01:34 AM
Chris00SS's Avatar
Hey, new to the site just wanted to ask a related question bout this. When i turn my car off and lock the doors the alarm will set itself right after all the doors are shut but the horn blasts twice as loud as all h*** every time twice just wondering if this is normal or not. I know something is wrong cause it'll sometime blast the horn twice a couple hours later like its arming itself again sometimes. Anyone every have a prob like this?
Old 11-12-2008, 01:37 AM
13lu91rS's Avatar
yup.. unplug your shock sensor.. thats what fixed the problem for mee!!
Old 11-12-2008, 06:55 PM
Chris00SS's Avatar
Hey thanks bro that did the trick! It was getting pretty dam anoying hearing the horn go off like that every time i armed the alarm. Those sensors must go out pretty easiely cause my car only has around 63 thousand miles on it
Old 11-12-2008, 07:26 PM
80k here!
Old 11-12-2008, 07:27 PM
13lu91rS's Avatar
mine just went out and i had 130 on the bottom end of my motor/chassis
