subs picked, but need amp advice.
im planning on getting a set of these MTX Model T8512-44 Description 12" Subwoofer, Impedance Dual 4 Ω ,RMS Power (Watts) 500 ,Rec. RMS Amplifier
Power (Watts) 250 - 500 ,Sensitivity 92.19dB ,Voice Coil 3" Magnet Weight (oz.) 160 ,Mounting Depth (inches) 7-3/4" ,Sealed Enclosure Net Volume 1.25ft3 ,Vented Enclosure Net Volume 2ft3 ,Speaker Displacement .09ft3 ,Volume Displacement (SD x XMAX) (in3) 73.61 ,Tuning Frequency 34Hz , what would be the best amp to get 400-450 wats to each sub? should I go with 2 amps, 1 for each?
I carry MTX. Don't know what kind of price your getting but I can do a pair of T8512-44 for $612.00. Add an MTX JH1200 Class-D monoblock amp to it for an additional $359.00 and I throw in a 4awg amp wiring kit for FREE. The JH1200 would be a good choice to power those. It would put you in the right power range for those subs.
Like the pic of your car. Not sure if you remember me at the show but I was a sponsor this year.
http://rockfordfosgate.com/rftech/wo...2&woofer_imp=4
Click search.
The (+) and (-) on the far left it the amplifier Pos., and Neg..
Unless your Amp is 1ohm stable , wire it for a 4ohm load.
Click search.
