Doing VATS bypass need help
Ok, Which side is the BCM side that you plug the resistor into for the VATS bypass? Is it the female which has black and white wires or the male side that has orange wires?
Here is the tread with my problem...If anyone has any input.
https://ls1tech.com/forums/general-m...on-system.html
The purple/white & light green are the wires from the BCM.
The wires wrapped in orange are from the key cylinder wire.
You want the purple/white wires.
How to Bypass your VATS
Diagram for doing the bypass
