Intermittant Flashing "Check Gauges"
Old 03-11-2009, 10:27 AM
3zman's Avatar
Default Intermittant Flashing "Check Gauges"
I hope this is the right place to post this. My 98 camaro has started flashing "Check Gauges" on the dash. Everything seems to function properly, ie., oil pressure, coolant temperature etc..
Any ideas as to what is going on? At this point it is just an irritation but it would be good if someone that has been through this before could give me a little info. I searched but couldn't find reference to this particular problem.
Thanks
Old 03-11-2009, 11:30 AM
Havok2's Avatar
ur alternator is goign bad.
that was the sign for me, check your volts...prolly low.
Old 03-11-2009, 12:48 PM
vjo90rs8's Avatar
what about gas level, that will set off the check gauges light too
Old 03-12-2009, 10:47 AM
3zman's Avatar
Thanks to both of you. The car doesn't get driven as much as it should. Do you have any recommendations for the alternator in terms of manufacturer? What should I measure when the alternator is running - 13.6?.
The gas level is at least half full.
Old 03-12-2009, 11:17 AM
vjo90rs8's Avatar
when the engine is running the voltage should be 14.4V
Old 03-13-2009, 11:41 AM
3zman's Avatar
Thanks, will check this weekend.
