Gauge Cluster will not dim and Temp gauge flaky
This is on my 95 Firehawk.
My gauge cluster will not dim, but the interior lights do come on when the thumbwheel is turned all the way up. If I turn it down, it doesn't dim, just stays the brightest that it can.
I've already replaced the dimmer switch.
Also sometimes the temperature gauge does not work, it just stays below 160*. I hooked a datalogger up to the car and the computer is reading the correct temperature. Is there a method to diagnose whats the problem with the gauge?
Any suggestions welcome.
Thanks
Thanks
