Using SLP's Fan control Switch w/ Emblem-Pro Swicth Plate
I'm going to order a switch plate from Emblem Pros, and one of the switches will be for my SLP Fan Control. Emblem Pro has the switch for it, but i wasn't sure how to "migrate" SLP's controller with Emblem-Pro's switch; do i just just the switch off othe SLP controller and hookup the one from Emblem-Pros?
they offer a 3-pin/3 postion switch; is that what i want?
"...3-Position switches are used for variable speed cooling fans. It will be up to you to supply the proper relay. This switch is a 3-pin switch...."
here is what i have done with mine until i can figure something else out, you can see there is a little gap on each side because the SLP fan cover is square and the emblem pro is circle.
1 Post
nightrydass, did you ever figure this wiring out? or did you just do like transambandit did?
my slp fan switch is round, and doesnt look like it will fit in the hole in the emblempros switch plate.
