so ive got an electrical question...
Old 05-23-2009, 07:11 PM
C Murda's Avatar
Default so ive got an electrical question...
if i were too hook up an ammeter in amp mode with the 2 leads in place of a specific fuse, i should be able to see if that particular circuit is drawing any amps correct? so say i were testing for a short somewhere and the ammeter got no reading (when testing through the fused circuit) then that means that particular circuit is not drawing anything correct?
Old 05-23-2009, 07:56 PM
cheechz's Avatar
sounds correct. put the ammeter in place of a fuse and you see no reading then there is no current flowing.. or theres a problem with the ammeter.
Old 05-23-2009, 09:08 PM
C Murda's Avatar
ok thanks...yea the meter is in good tested working order.
