The lights use thermal flashers and there is a separate one for the hazards and a separate one for the turning lights. (They are different part numbers.)
There is no turn signal relay but the flasher is clipped to the back side of the lower dash just to the right of the opening when you remove the knee panel under the steering column. It's close to the OBDII connector port.
