1 brake light dont work when lights are on.
Both brake lights work fine until I turn the lights on, then the passenger brake light doesnt work. both tail lights come on , but the passenger side doesnt light up for braking. Any ideas?
Ungrounded Moderator
Did you test the ground or are you just assuming it's okay? The fact that it joins another ground wire at some point does not mean it's a good ground. The wire between the sockets and the splice could be broken or the sockets themselves could be corroded or damaged. Always check the basics before trying to find some more exotic cause of a problem.
